CWM recovery ask
    Re: CWM recovery ask
    Originally posted by MARIANOTE View Post
    pues yo CX919 1gb, gracias leolas!
    si pones un how to con eso del terminal emulator... o si es mas facil con RKflashtool no se a mi me jodio el mk802 una cosa que hice con terminal emulator ;S
    gracias por la onda!
    Me puedes pasar un enlace a tu stock rom? O a tu recovery.img de stock?
    leolas
    My devices:
    Gearbest.com)
      leolas
      aqui lo tienes, sacado de la finless 1.4
      no tengo ninguna stock, creo que el kernel es stock 720p este
        Te funciona esa rom bien?
        leolas
        My devices:
        Gearbest.com)
          leolas
          si, perfecto, salio 1.5 pero da problemas en kernel parece y esta va como un tiro
            Okis paso a prepararte el recovery, es beta, así q asumo q sabes flashear la rom desde cero en caso de desastre. Debe funcionar bien, pero ya sabes...
            leolas
            My devices:
            Gearbest.com)
              I am too looking for a CX-919 CWM recovery.
              I have found the generic one, but I'm not too sure about it .
              How would you go about flashing? using the finlessflashtool and just flash the recovery img?
              Sorry If you had answered this, my Spanish is rusty .
              "Talk is cheap. Show me the code." - Torvalds, Linus
                Sorry me for speak only in spanish, yes doing it, and it can be flashed with the same tool included in finless roms. I will post it just when I finish it.
                My devices:
                Gearbest.com)
                  OK Uploaded, Please remember that it is a BETA, I don't have the device so I cant test it. So flash it if you know what are you doing. Be sure that you know how flash a rom, I have no responsibility if you brick your device, bla, bla, bla...
                  Flash it with the tool included in finless rom, deselect all options except recovery and chose this one.
                  All credits to fun_ from androtab, he did all the hard work, I only modded it a little, modify some little things, and add a kernel to the recovery, so we can format and flash the kernel partition from cwm. So it is not my work, it is fun work. If it works well for you, then Thanks to fun_, if something fails or not work good, for sure it is my fault.
                  http://www.freak-tab.de/leolas/cwm/c...m-recovery.img
                  My devices:
                  Gearbest.com)
                    leolas
                    si, siempre flasheo por Rkflashtool como explica Finless
                    Downloading!
                    A question: can be used only with USB mouse? i dont have keyboard :S
                      Pues valor y ya comentas como te va
                      leolas
                      My devices:
                      Gearbest.com)
                        leolas
                        y lo del mouse? gracias por el curro
                        nice work, testing tomorrow noon, (need to watch footbal saturday )
                          When you move your mouse up, is like up arrow in the keyboard, when you move down is like arrow-down, to right like arrow-right and left like back key
                          My devices:
                          Gearbest.com)
                            thanks!
                            PD: si anda te debo una birra leolas!
                              thanks!
                              Debe funcionar, pero al no tener yo el mismo stick no te lo puedo garantizar
                              leolas
                              My devices:
                              Gearbest.com)
                                Thank you leolas. This image solved the boot to black screen problem I had when booting to recovery.
