Overheating Mecool M8s Pro L and Pro + (and others ?) - Options ???
Originally posted by mirbg View Post
You can get 5V from the USB slots
3.3V from UART is nice if you want slower &/or quieter.
I found 5V 30mm fan listed as a Pi Fan on that Bay for a £.
Just meant that putting fan inside leaves the lid with a hole but no fan "bump" !!(though you can fit a fan and have no hole - just space it from the lid a couple of mm and the circulation is enough, at least in England, see pic post 1)
Thanks for the posts
Originally posted by P.XJust meant that putting fan inside leaves the lid with a hole but no fan "bump" !!(though you can fit a fan and have no hole - just space it from the lid a couple of mm and the circulation is enough, at least in England, see pic post 1)
Strange...in my case it made little difference with the fan inside and lid lifted about 1mm...just 5-6C lower.
EDIT
Sorry - Wrongly annotated - Pro L so should be noted as with 2x Slots cut in grooved lid.
I'll re-test ...Last edited by P.X; 03 February 2018, 17:01.
Originally posted by clarkss12 View PostHow does one solder the fan leads to the board, the connections on the board are soooooooo tiny????
5V USB are big pins sticking through board on the underside.
HTH
3.3V UART are relatively big pads (square one is -ve, opposite end of 4 is +ve) with holes for small wire.
HTHMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Albertron View PostIs it possible to add a fan and that it is deactivated when we turn off the tv box? I need this, because I use the TV box to sleep and I do not want the fan to be on all night.
Noise is not a worry if you use a 5V fan at 3.3V, at least the one I got.
Energy is vanishingly small, much less than most standby current.
Wear and tear would be my only concern.
You could use a radio remote power socket switch.
Often come in packs of 3 or 4 but a pack of 2 can be found for about £10 I think.
If you can find a power line on the board which is switched then someone could probably design a simple FET/transistor switch to put in line with the fan !!!
Otherwise some passive options are detailed early on ....Last edited by P.X; 09 February 2018, 12:26.
Originally posted by AlbertronIs it possible to add a fan and that it is deactivated when we turn off the tv box? I need this, because I use the TV box to sleep and I do not want the fan to be on all night.
There are currently 1813 users online. 2 members and 1811 guests.
