Overheating Mecool M8s Pro L and Pro + (and others ?) - Options ???
Originally posted by Jancales View Post
And it has 2mm thick Thermal pad, not adhesive or whatever
Pads are much worse than epoxy or good glue.
Graph in Post 1 shows my test gives 11°C poorer than thermal paste.
Would be nice to see your comparison if possible, pad vs paste ???
Oh dear, give with one hand and take away with the other.
It's S812 soc .
If I have time I will test again.
I tested it long time ago, never reached 50°C even after hours of playing movie.
It's S812 soc .
Maybe better, thinner pads are closer to paste??
Some data
This is my solution of the problem with the heat:
40x40x10mm Evercool fan on 5V , connected on the back of the USB:
Results:
Original HS - max temp with StressCPU- 82C
40x40x11 Aluminium HS with lifted lid about 2mm - 80C
40x40x10mm fan on 5V with modded lid cover (30 holes) and stock HS - 67C
40x40x10mm fan on 5V with modded lid cover and stock HS - 57C
40x40x10mm fan on 5V with modded and lifted lid about 2mm and stock HS - 53C
The box is practically noiseless, absolutely quiet with this fan.Last edited by mirbg; 07 February 2018, 13:51.
Originally posted by wimpie007 View PostStock heatsink, 30mm hole, with 12v fan running on top (running on 3.3v) 50 degrees when watching netflix HD.
The fan 'sucks' air out of the device, instead of blowing it in.
I found you can fit some inside with the std. HS and a small lift of the lid.
Are you sure it is 12V ? Most won't run at 3.3V, but will if rated at 5V.
Yes, that works too
Fan inside with lifted lid will hardly make any noticeable difference - in my case the temps went down from 80 to 74C degrees. It just needs more fresh air from outside...
There are currently 1494 users online. 1 members and 1493 guests.
