I would like to have the better way to cool the box with less sound possible.... perhaps 3.3v or 5v is necessary i don't know...
Overheating Mecool M8s Pro L and Pro + (and others ?) - Options ???
Yes from internal storage.
Haven't managed to test every combo yet !!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by diabolyk View Postyes thanks i have see those but I don't have a pic of where to connect it...
I would like to have the better way to cool the box with less sound possible.... perhaps 3.3v or 5v is necessary i don't know...MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by diabolyk View Postok
and i can pick the pin topside or bottom side it will stops when i power off ?
5v vs 3.3v : is there a real difference for cooling ? and for noise ?
A slower fan will definitely reduce the noise, but you will have to do some trial and error on how much you wish to slow the fan. I am using a "cheap" fan, and reduced the fan voltage by half, but I can still hear it. I have ordered a more expensive 30mm fan with ball bearings, and will be testing that, when I receive it.
You need to read this thread, there are some very good ideas, discussed here.
EDIT: P.X has a thermal switch on order, to test. It will turn the fan OFF when the temp is low, and turn ON the fan with the temp rises........ So stay tuned!!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by diabolyk View Postok so i should put it on 5v you think ?
or the gain of temperature between 5v and 3.3v is not interesting ?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
3.3V UART supply is not switched.
3.3V or less is good speed for cooling and less noisy - I use a small resistor to get correct voltage/speed - see previous posts.
Best fan I have tried is Pi Fan @ about $1.21 on the Bay and comes with 4xscrews and nuts (not needed but it shows you which type I bought)
All the info should be somewhere in this thread.
Top-side 5V USB is only on a little resistor by the USB socket - very careful soldering required (see my vid)
Underside 5V is much easier and safer to solder to ....
KSD 9700 NO switch
Just tested 55C Switch and only switches on at 78C (Probe Temp 53.6C)
Has to be well attached thermally to get to switch-on temp !
I am guessing a 45 or 50 switch would be better.
Item number 322989226698 on the Bay UK - Great seller. Super fast delivery.
The Normally Open version of KSD 9700 is needed - It has a 开 Kanji (Crossed-out Tower?) on it.
Some sellers show wrong version in pictures (same pic for both?)
Write a note - Must be version Open Circuit at Room Temp.
Has to be well attached thermally to get to switch-off temp !
The Normally Open version of KSD 9700 is needed - It has a crossed out Tower Kanji on it.
I am watching this closely....... I am confused about what you said on switching OFF. It turns the fan on at 78C, but what temp does it turn the fan OFF??
Nominal-55C Switch
Switch ON Temp 78C (CPU-Temp -- Probe Temp 53.6C)
Switches OFF at 68C (CPU-Temp)
I'll try a 40C when it arrives ...
The trouble is these little switches have pretty wide manufacturing tolerances can be +/- 5C of nominal ON Temp and OFF defined as ON-15C(+/-5C)
There are currently 3024 users online. 2 members and 3022 guests.
