Best to check temps by installing CPU Temperature from Aptoide (old app, allows for a temp overlay while running apps)
Overheating Mecool M8s Pro L and Pro + (and others ?) - Options ???
Originally posted by LilSnoop40 View PostOk I installed the CPU Temp app and have the overlay running showing 165-170*F while watching a 1080 with 5.1 audio is this safe?
thanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by LilSnoop40 View PostWell that’s good would you say I don’t need to do anything to it, I just have it resting on it’s side.
P.X can you confirm what I bought will work please. Below is the fan:
MakerFocus 2pcs Raspberry Pi DC Brushless Cooling Fan Heatsink Cooler Radiator Connector Separating One-to-Two Interface 3.3V 5V for Raspberry Pi 2/Pi 3/3B+ and Pi Zero/Zero W or Other Robot Project https://www.amazon.com/dp/B072FW3DDQ..._jB2aBbX07FEY7
Can you tell me what resistor I need I can pickup from the local store:
Welcome to RadioShack's official website. Search and shop for electronics, gaming devices, powerbanks, audio products and business traveling gear.
I thought you said you had used the 1mm resistor 33ohms but I see different ones and have no idea what I am looking at.
thank you
Originally posted by LilSnoop40Do you have any mods done to it? I am going to add the 30mm fan and 1mm resistor. As my runs around 150-180 idle to watching a movie.
In two days I am going to replace the original heatsink with 38x38x11,5mm Alu's one.
I have 15x15 heatsinks on RAM modules and the emmc chip.
There are currently 2792 users online. 2 members and 2790 guests.
