Overheating Mecool M8s Pro L and Pro + (and others ?) - Options ???
Originally posted by Jancales View PostP.X I'm looking to install a fan underneath a box ( not a Mecool) as I think it's more aesthetic that way. I will make 5cm diameter hole in the bottom of the box and mount the 8cm usb fan right to the bottom of the box.
I will leave a 2 cm space under the fan, so will use some footings.
The box has perforations at the sides, but not in the top lid.
What you think would have the most positive effect, let the fan suck hot air out of the box, or let it blow air inside?
Probably both about the same, but good if you can try both ways and report back with the results ....
Nice little fan. How well does it work ?
Do you need holes in the lid of that box ?
Originally posted by dbramm22 View PostI just finished installing this 35x35x8mm fan/heatsink. I'm letting the heatsink compound cure, but I'll post results when it's up and running.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
The 80x80x10 usb fans arrived.
I did some simple test with a Pro+ that has a 40x40x11 heat sink installed, by placing a fan right under the bottom, on 2 cm footings.
I didn't drill any holes or whatever in the base.
Running Stress CPU it would max out at 69°C. Suction gave a little better result as blowing.
Mind you i'm living in a tropical country. Without the fan it will reach 80°C within 10 minutes with Stress CPU.
In about a week i will test with a Vorke Z6 with a 76mm hole drilled in the base.
There are currently 5091 users online. 1 members and 5090 guests.
