Overheating Mecool M8s Pro L and Pro + (and others ?) - Options ???
Adding an external WiFi antenna ...
Video (uploading)
Cheap 8db Dual Band seems to work best.
150mm Pigtail.
Tools and Parts
Locate antenna connection (front Left)
Close-up - Solder here - see video.
2mm pilot hole, then 5.5mm and file to correct shape with a flat area ...
Inside - Flatten off the ridge as needed
Socket with a crenelated washer
Split washer and nut
8db Dual Band - Nice.
Originally posted by Albertron View PostHi. I have a fan connected to 5v and now I want to solder a resistor to decrease the voltage, since the fan is very noisy. Before I had it connected to 3.3v and it was very silent. What resistance should I buy to get the 3.3v? The characteristics of my fan are: 5v - 0.15 A
Others have used a cheap variable Buck voltage supply (about $1 or less)
or a multi-turn variable resistor (see previous posts for details ...)
depends what you can get locally or cheaply from the web ?Last edited by P.X; 01 December 2018, 21:20.
Possibly 16ohm (20 or 33ohm may also work and be even quieter)
Hi all,
I don't think it was mentioned before, but regarding having quiet fan - i took option to install 12V fan and connect it to switched 5V on USB port. For example, i used this fan: https://www.chipoteka.hr/artikl/141462/ventilator-12v-40x10-mm-sunon-ee40101s11000u999-2440001952 , and without any resistor.
Fan has operating voltage starging from 4.5V, so on 5V it will spin slowely and very quietly, which is sufficient for cooling even with stock cooler on the processor.
Before fan, i had idle temperatur of ~51C (ambient 23C), and when watching 2160p it peaked at ~69C (this is with holes on the top side of the case). With fan, idle temp is 29C and watching 2160p around 35C.
Fan is very quiet, you can hear it faintly only from 15cm away.
br,k.
br,k.
Thanks for info. Finding a 12V that spins up at 5V is a good solution. Not all work, so always good to get info on any that do.
Good result.
I have replaced quite few heat sinks on the M8S pro+ S905X box since this thread emerged.
The last lot of boxes I received had a larger heat sink than the previous ones, more rigid aluminium as well, but yet not good enough.
I notice that the surface of the processor on this last lot is much rougher. Could this mean that the Chinese are now using knock off Amlogic processors?
On another note, I use 5V fan, and find lots of 3.5V sources on the pcb, but they all remain active when box switched off.
Is anyone aware of a 3.5V source that switches of with the box?
Originally posted by P.X View PostThanks for the info.
Photos ?
Not found any switched 3.3V
With this lot not anymore, and it is also very difficult to clean the thermal paste from the processor for that reason.
If you mean the heat sink, this is the one they use now
Originally posted by Jancales View PostP.X Just received the fist lot of Pro LB, noticed it has a steel plate mounted under the PCB. Don't know this has always been as never had Pro L.
Wanted to fit 40x40x11 heat sink but noticed the lid can't be properly closed then.
Is this normal or is this something that has changed?
Very interesting ... Never used to be a metal plate, just like the pro+ before.
I think something may have changed spacewise above board as well. I always used little rubber pads and spaced the lid to have a small gap so can't be sure, but I am pretty sure you could screw the lid on properly if you wanted too before.
PiX if you can?
trebor =P.X;n766986]
PiX if you can?[/QUOTE]
I did make a hole in thee bas already to mount my fan underneath, and fitted a 50 x 35 x 10 heat sink which allowed me to close the lid
By the way @ trebor I don't receive notifications anymore from replies to subscribed posts.
You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
There are currently 3733 users online. 1 members and 3732 guests.
