Overheating Mecool M8s Pro L and Pro + (and others ?) - Options ???
    Wow mirbg.
    Not much difference between mx-2 and NH-N1 ,I have used both on P.C cpu.
    39°C @100% now that is amazing.well done.
      Wow mirbg.
      I would run cpu stress test min 20 minutes.
        Toohot has had his wonderful mod pics and entire post removed for some reason ???
        Hopefully a Forum Moderator can get it back up for all of us to see again ...
        Popcorn (where is the popcorn smiley?)
        Back up again
        Thanks mods
          Thanking P.X and Mods
          Great work.
            Originally posted by Toohot
            Wow mirbg.
            Thanks, mate!
            I replaced the standard heatsink with bigger one too, using it with fan on 5v.
            This is my setup:
            This is older version with plates on ram modules on the underside, now I am using copper heatsinks:
              Hi all.
              I forget to let everyone know a easier way to remove original heatsink.
              I removed heatsink using thin nylon fishing line dipped in isopropyl alcohol,then sliding underneath between heatsink and cpu pulling and moving side to side while holding line tight. Then used remaining cutoff copper plate to loosen.came off easy.
              if you do not have fishishing line, try tooth floss. The trick is to keep dipping it in alcohol.
                Vorke Z6 DDR4 3/32 Gb
                Heat sink 33x45x10 70mm hole in bottom plate with 80x80x10 USB fan in suction mode underneath
                Ambient temperature 26?C
                Idle 38?C
                15 min CPU stress test 54?C stable for the past 12 minutes
                Click image for larger version  Name:	20181112_225421 (Large).jpg Views:	2 Size:	79.7 KB ID:	751412
                Click image for larger version  Name:	Vorke box.jpg Views:	1 Size:	91.8 KB ID:	751411
                  Originally posted by Toohot View Post
                  Hi all.
                  Top Tip
                    Idle 38?C
                    Nice - That'll do the job
                      If anyone has received their S905X2 new android tv boxes please could you test out the temperatures especially when playing UHD bluray uncompressed files.
                        Where would I find UHD bluray uncompressed files????
                          I tried uncompressed .m2ts 70GB file on my modded box and max temp it reached was 29C
                            Are you sure about that? I haven't ever seen 29?C on idle on any box.
                            Does your mod include some freezer
                              No, I posted some pics several post ago, I have fan on the cpu, modded heatsink with Noctua NT-H1 cooling thermal compound, heatsinks on the ram modules, storage chip and on underside of the box one more heatsink beneath the core and again on the ram:Click image for larger version  Name:	448313D9-7FF2-40B1-B7A7-E5F727BC90F0.jpeg Views:	1 Size:	136.1 KB ID:	751898Click image for larger version  Name:	95E83D00-7B67-484D-9B34-22B78DDEFA44.jpeg Views:	1 Size:	136.1 KB ID:	751899
                              Click image for larger version  Name:	image_35956.jpg Views:	1 Size:	139.8 KB ID:	751897Click image for larger version  Name:	image_35955.jpg Views:	3 Size:	124.0 KB ID:	751896
                              The max temp under full load with StressCPU is 39C.
                              There is no single 4K movie that can stress the cpu that much as StressCPU.apk does.
                                just DM'd you a link.
