Overheating Mecool M8s Pro L and Pro + (and others ?) - Options ???
Originally posted by P.X View PostSuper Cheap Laptop Cooler
£2.18 ($2.80)
https://www.aliexpress.com/item/2-US...911598882.html
80mm Fans (all images - Click for larger)
Simple clip-on back
Cut one set of wires ...
Cut in Half (Cooler + Spare)
Two back legs are taller so swap the taller leg from the spare fan piece.
Gives a slight slope to the front ...
Tape up the wires to give bit of strain relief...
Do a better job than this !
Et voila, a little cooling plinth.
Slope + Air Gap - Side View
e&oe
Since I have done one without the hole, because the M8S Pro+ has to slits in the bottom plate anyway, and it makes 1°C difference with the hole.
On idle it runs 41°C and with Kodi playing a FHD stream for 90 minutes it's maxing out at 52°C.
I also lowered the feet to 5mm while gluing the fan on the rubber feet of the box, which is about 2mm.
Take note the I put the fan in suction mode, coz blowing will make noise, and runs significant hotter as well
The fans are 20$ for 10 piece, with free shipping on the bay.
Edit, I also have 40x40x11 heat sink mountedYou may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Originally posted by Jancales View Post
I posted before about the 80x80x10 fan I mounted under the M8S pro+ while cutting a 80mm hole in the bottom.
Antenna Upgrade
posted elsewhere
Originally posted by P.X View PostUpgrade Wi-Fi Antenna
My brothers M8S Pro+ now connects via Wi-Fi where before it needed an Ethernet connection.
1x M8S Pro+
Soldering Iron & Solder
Cross head screwdriver
Wire cutters
Leatherman/Pliers
Craft knife
1x 6Db Wi-Fi Antenna (or better) - suitable Dual Band if your box has 2 bands.
1x SMA Pigtail (bare ends for MeCool or plug if you have a little socket on your MB)
Open the box (4x cross head screws behind the little rubber feet)
Click Larger
This is the solder connection (pads look like a socket should be fitted !!)
Click
Cut one slat on the right of the base, just behind, or in front of the middle (Wire cutters/Craft Knife)
Fit in the SMA socket (Leatherman/Pliers)
Solder to the pads, the same as the fitted antenna
- Core to Core Pad ... Screen to Screen Pad
Put back together
Needs two more feet than I have !
e&oeLast edited by P.X; 30 October 2018, 21:19.
Before I start, I would like to thank P.X. and all for ideas.
My Mecool has finally landed.
1. idle temp 38-39°C
2.Ambient room temp 22-23°C
3.Internal box Temp 31°C
4.CPU Stress Test 26 minutes 59°C
5.Fan speed slowed down.Just audible @ 1 metre.
Please see attached photos below.
Edit Update
In last 2 days Idle temps have dropped to 35-36°C
Internal box Temp 28°C
Ambient Room Temp 25°C.
Must of settled In ?.You may only view thumbnails in this gallery. This gallery has 15 photos.15 PhotosLast edited by Toohot; 05 November 2018, 09:59.
Originally posted by Toohot View PostBefore I start, I would like to thank P.X. and all for ideas.
Edit Update
Very nice, and complete job.
Well done and thanks for the photos.
There are currently 1899 users online. 0 members and 1899 guests.
