Overheating Mecool M8s Pro L and Pro + (and others ?) - Options ???
Originally posted by panchovilla View Post
Thanks for the heads-up.
I soldered mine on the USB pins. Full-on 5v. I don't mind the noise. I have a sound bar. I can't hear it unless there is some complete silence.
I used epoxy. lol Slow set one that melts only when metal turns orange.
Mine is in my bedroom and at 5v it was a little annoying. At 3.3v I can't hear it from 1' away.
Can you detail what 3.3V source you used ?
Pics if possible.
Is it a switched supply ?
Nice work by the way, shame that Fan/HS is so expensive from AliXpress, and the US **** seller doesn't ship to UK (would be expensive if they did anyway !!!)
Pm me your address and I'll send you my extra!
Originally posted by dbramm22 View Post
No problem, Very good my man! Post your temps during stress CPU when you can. I'm interested in seeing your temps vs mine with mine being wired for 3.3v
And some baseball game . 60*c.
I found a 3.3v source by the lan port. Vertically there were 4 solder points. Lan TX, Lan Rx, gnd and 3.3v.
Can't find any 3.3V switched so I'll just use USB 5V and a resistor ...
Originally posted by Novato View Post
I have one of these arriving tomorrow ...
($5.92 Free Shipping - Ordered 12-Sept - 9 days delivery CN to UK)Last edited by P.X; 20 September 2018, 18:55.
Fitted in my Pro L
Too loud @ 5V
Slight noise at 3.3V
Fitted 20ohm resistance and runs very quietly at about 3V (from USB 5V supply)
Fitted my Pro+ lid as hasn't got a hole in it !!!!
This gives a nice 2mm gap all round the lid - I would space a Pro L lid to do the same.
Very Nice
Running Temps ...
Ambient 19°C
Idle 46°C
StressCPU 100% ~ 65°C
KODI - 60Hz Loop 250mbps hevc 4K - 57°C
YouTube - Venom HD 1080p - 52°C
Forgot to say this box has a base Cu-Plate so temps lower than std. by about ~5°C
20 Ohm resistance
Tried 15 Ohm for approx 3.3V (used 33 // 33)
Settled on 20 Ohm for approx 3V (used 100//100 for 50 and paralleled 33 e.g 50//33 to get 20 as I didn't have a 20 Ohm !!!)
In this picture there is a spare 33 Ohm from testing 16 Ohm ...
There are currently 2946 users online. 0 members and 2946 guests.
