Overheating Mecool M8s Pro L and Pro + (and others ?) - Options ???
Originally posted by panchovilla View PostBetter on top of the heat sink for sure.
The one without the footings doesn't make much difference in result, but is a little noisier because it makes the blade vibrate. The footings are 2 cm, which i consider a bit high and not needed, so will look for half or less that size
You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Originally posted by Jancales View Post
Of course on top will be better, but again less aesthetic in my opinion.
Yes, very nice. Looking forward to your results. How noisy/quiet at 5V ? Can you post a link for the combo ...
5v is to loud for me so I think I'll open it back up and resolder to a 3.3v source.
Here's a link to the unit, although the one I purchased was on E B A Y - Just search for "AP3505LB-J70(S)"
https://www.jameco.com/z/AP3505LB-J7...M_2235292.html
Originally posted by dbramm22 View Post
So far results are good! Idle temp is around 43degC and load temps while watching 4k is 56degC. Before with the stock heatsink I was getting up to 80deg C!
Way too much from aliXpress ($25)
POA in the UK !
I'd fit a resistor, or one of those little <$1 Buck driver things ...
Nice looking fan/HS
Got a pic of the box with the lid on ? Great looking fan with a plate.
I'll get a pic of everything once I get it resoldered. I didn't drill holes or anything. The way the heatsink is designed I decided to just let the side vents do the job. It's very clean and works very well imo!
Yeah, the side vents on this box is pretty good at least.
Just did the OTA updates. Fixed my youtube problems.
There are currently 3692 users online. 1 members and 3691 guests.
