NEOTV CROM 1.3A MK802IV Old Wifi,MK809III,UG007B,QC802,Cloudnet Go CR9 *Update*
AW: NEOTV CROM 1.3A MK802IV Old Wifi,MK809III,UG007B,QC802,Cloudnet Go CR9 *Update*
Originally posted by fabienk View Postthanks for the update, i'm going to test it right now !!!
EDIT:I still have the same problem with sam's 1080p kernel ( lastest ) + edited build.prop ( density = 240 )
.. need an update 1.3B ?!!?
Neomode, I flashed your ROM, but my screen goes down-left, screen scale not help me ('screen scale' scale from center, but desktop is go from down-left), I flashed 3 times with erase IDB .. with your kernel, sam321 kernel 720p,1080p ... same thing ..
sorry for my english .. will make a photo ..
can I fix it somehow ? with Neomode 1.0 was ok.
Originally posted by neomode View PostThis can have more resons. First the Launcher itself. Try a nother Form Playstore.
even in Google play, icons are huge, mouse pointer is also huge
Originally posted by neomode View PostThan the Kernel. I have include Sam 321 720p Kernel. When you want to flash a nother kernel you must name it kernel.IMG and copy it over my Kernel.
after several tests, "the mess up" comes when i increase the density in the build.prop, over 160 starts the problem
Originally posted by ruslanx View PostNeomode, I flashed your ROM, but my screen goes down-left, screen scale not help me ('screen scale' scale from center, but desktop is go from down-left)...
scaling troubles
Originally posted by ruslanx View Postfor me scale not working, it's cut my desktop, its zoom-ing from center in all direction, but if desktop is left-down corner it go cuted from that corner ... back to NEOTV CROM 1.0 + kernel Sam321 720p 1.7ghz ram 1200mhz - and all is ok
screen on left botton and if i scale it, it cut a little at side and at bottom
OK i notice the Failure and will see how to remove it. Can some one try the kernel from strauzo for this device and see if the failure still exsist. For version one I use the stock kernel. I think this is a kernel related failure.
Neomode
Neomode, it's not kernel fault, I flashed all kernels from Sam321 with NEOTV CROM 1.3A and , nothing changed, after flashed NEOTV CROM 1.0 with same kernels from Sam321 and all is ok .. may be boot animation or something else affected some system (screen) settings ...
No I don't think so but will test it.
It can be a kernel problem to because strauzo make a kernel to fix this.
The Boot animation can not make any change to the screen. In there only pictures to play on boot up.
Neomode
Neomode
There are currently 2009 users online. 2 members and 2007 guests.
