NEOTV CROM 1.3A MK802IV Old Wifi,MK809III,UG007B,QC802,Cloudnet Go CR9 *Update*
Originally posted by topoalm View PostI downloaded the file, but how to install a xxx.img???
and after that run the ROM_Flash_Tool_137.exe
also in this thread Sam tells you what to do:
Originally posted by sam321 View Postfor the old WiFi MK802-IV or UG007B or QC802 with RTL8188 wifi and RDA 5876 bluetooth
instructions
remove any SD card before flashing
launch ROM_Flash_Tool_137.exe
put your stick into flash mode
click on Erase NAND (IDB)
and then click on Flash Rom
once done the stick will reboot into CWM you can choose to reboot to system at this time
http://www.cloudstor.es/file/m1_NTY2Ng/
Originally posted by makelele View Post
if that do it perfectly, but I downloaded from website vondroid a rar that only comes img file with extension.
the question is that when you open the rktools, have different sections, parameter, kernel, boot, etc ...
where this would go a 500mb file???
thanks
Originally posted by topoalm View Postif that do it perfectly, but I downloaded from website vondroid a rar that only comes img file with extension.
thanks
everything you need its here:
Originally posted by pancia50 View PostThanks, but it's not the latest one.
And play store says it can't update, it there a way to update it?
worked for me.
I have uninstalled -> install sam's one -> update. (if you cant update straight away just uninstall and install from play store)
there is a new update available from http://www.rikomagic.comMK802IV FW(130905):S/N from 201305****to 201306****
There are currently 1950 users online. 2 members and 1948 guests.
