NEOTV CROM 1.3A MK802IV Old Wifi,MK809III,UG007B,QC802,Cloudnet Go CR9 *Update*
Originally posted by sam321 View PostIf you need to scale the Screen go to Settings>Screen>Screen Scale and use the slider to adjust it
And the display gives a perfect 1:1 pixel mapping , my question is does the line
"xscale=95 yscale=95" is resposible for some scaling , if so how can i cancel it as whatever i
Modify in t/sys/devices/virtual/display/display0.HDMI/scale , it resets in the next reboot , thanks.
New ROM and XBMC
Hi team!
I'm new as Android TV player user, but very intrested in evolution of new NeoROM. How is development is going? Could you inform, please, when new release will be available for the old wifi chip? Cause as after installation of new official ROM (in tested purposes) only negative impressions are occured. Additional question - which ROM with which kernels is better to use for XBMC? From which overclocking is necessary to use cooling?
AW: NEOTV CROM 1.3A MK802IV Old Wifi,MK809III,UG007B,QC802,Cloudnet Go CR9 *Update*
Making progress with the Rom.
Must do some final Test with him to make sure all went fine :thumbup:
You can use my Rom with any Kernel from sam321 for the old wifi.
When you use a Over Clocked Kernel make sure to use a CPU Cooler.
Neomode
Hey Neo,
danke für deine tolle Arbeit, bin sehr begeistert von deiner Firmware. Jedoch hab ich eine Frage bezüglich des Internen Flashspeichers. Ist es möglich den Internen Speicher und Nand Flash zusammen zu packen, so das es wieder 8GB gesamt ist? Der Interne Speicher ist schnell voll und Apps2SD funktionieren so bei mir nicht wirklich, hab mir extra eine 32GB SD Karte gekauft und da sollen die Apps eigentlich hin.
Cro
Need help
I have a CR9 Cloudnetgo that arrived yesterday (17-09-2013) and I've noticed that official firmware sucks because there is video stuttering all over the place... I want to use the stick as a media center and this is completely unacceptable.
So I've researched and found this forum. I've seen almost all threads but I'm missing something...
I have flashed the following roms:
- MK802IV_NEWWIFI_1080p_NEOTVCROM_1_3_20130809
- Vondroid Rom ported by sam321 for old MK802-IV or UG007B
- neotvcr_mk809_3_ug007b_20130615
But none of them has wifi! That is essential to me... I'm running out of options and I'm really tired of flashing roms...
Can someone please help me?
There's also a way to check it without opening the device with dmesg log. Abraço.
Originally posted by sam321 View Postfor the old WiFi MK802-IV or UG007B or QC802 with RTL8188 wifi and RDA 5876 bluetooth
I know how busy neomode must be so I ported the Vondroid Rom myself. all I have done is change the drivers so that WiFi and bluetooth work on our sticks, it is just to put us on till neomode does his ROM. The first boot will take a while so be patient
instructions
remove any SD card before flashing
launch ROM_Flash_Tool_137.exe
put your stick into flash mode
click on Erase NAND (IDB)
and then click on Flash Rom
once done the stick will reboot into CWM you can choose to reboot to system at this time
http://www.cloudstor.es/file/m1_NTY2Ng/
I have a strange problem with this rom. After flashing it, I am able to activate the "null keyboard" and also select it as default.
When I setup my playstore ID, download the app "QWERTZ Tastatur Deutsch extern" and try to activate this as input method it always jumps back to the input, that was selected before.
Anyone with the same problem?
I tried some other roms, but I only have the problem with this rom. Can I be related to the 720p kernel?
greetings
EDIT: I have the MK802IV with old wifi and bt
EDIT2: Solved the problem. I found out, the stick just needet some reboots and maybe swearingLast edited by hdmistick; 18 September 2013, 21:42.
Maybe a stupid question but... How to update/install when you don't have the original bootloader any more?
I have installed the 1.0 version on my MK IV a while ago and now when I push the pinhole I have got some kind of stock android menu.
Can I install the .img any other way other than the batch tool or can you give me a quick guide how to?
Also, how to output 5.1 / DTS over HDMI as this is not working for me in the 1.0 version.
The QX1 seems to have the same chipset
Looking at this thread it seems to have the same wifi and BT chipsets. http://www.freaktab.com/showthread.p...t-of-TV-Sticks will this kernel work?
There are currently 4169 users online. 3 members and 4166 guests.
