Also, I'm a complete noob at this. This is my first Android TV box.
My W95 box doesn't play smoothly in Kodi so I thought I'd try to dual boot to LibreELEC following the instructions here:
But every time I tried it just boots normally. My box is the 2GB version and I tried all of the 2g dtb files. I'm thinking my reset button may not be working correctly but I don't know what to expect if it is working correctly.
I can hold the button in while the W95 is turned on and nothing happens. Is this normal?
How can I tell if the reset button is working as it should?
