H96 MAX RK3399 ANDROID 7.1 4GB/32GB TV BOX FIRMWARE UPDATE 20180102
    Hey guys,
    Glad to share the firmware for H96 MAX RK3399 TV Box
    PC Flash Firmware
    Flash guide, please refer to: http://blog.geekbuying.com/index.php...utorials-tool/
    Have fun !
    thanks
    Today I check this firmware on H96 MAX with wifi chip 9377
      Originally posted by barto41 View Post
      thanks
      Today I check this firmware on H96 MAX with wifi chip 6255
      glad to help you.
        Hello GeekBuying_Rep, the wifi chip that has my h96 max
        9377 and not 6255
        I was not given time to test the fimware
        Thank you
          9377 and not 6255
          Thank you
          any ideas,just feel free to let us know.
            Hi ,
            a good idea is , to look for a Rom with QCA9377 support , that Users like
            "barto41" can use there Box again . He is not alone .
            greetings / gefattern
              Hi guys
              Only official rom 20171219 onwards works with our H96 ma wifi chip 9377, in case the unofficial rom does not work
                Hi ,
                thanks for your suggestion.
                this firmware is for 9377.
                  Hi guys
                  thanks for your feedback.
                  yes,this firmware is for 9377.
                  • gefattern
                    gefattern commented
                    Editing a comment
                    thanks for help
                  Hi guys
                  After using H96 MAX the rom has a lot of errors:
                  I can not connect the mobile via MTP
                  You can not make backup copy using the original application
                  Etc....
                  I hope some coiner prepares a good rom or a good update
                    Hi guys
                    Etc....
                    Hi sir,
                    ok,we are uploading a new firmware.
                    once it is ok,we will send you the link.
                      Thanks GeekBuying_Rep for answering and helping
                      Hi guys I wanted a question, what maximum memory capacity micro SD accepts H96 MAX RK3399 128gb, 512gb ????
                      Thank you
                        Thank you
                        128gb
                          Hi guys
                          Etc....
                          here is the new firmware http://blog.geekbuying.com/2018/04/h...date-20180124/
                            this afternoon I try to install and I tell you
