H96 MAX RK3399 ANDROID 7.1 4GB/32GB TV BOX FIRMWARE UPDATE 20180102
Originally posted by barto41 View PostCoupons Updated Every Day: https://bit.ly/2RnbHUi
Originally posted by negher View PostFIRMWARE UPDATE 20180124 - Ok WiFi, it does not work audio, it does not work shutdown off.
have you tested this firmware?
and how you set your audio?Coupons Updated Every Day: https://bit.ly/2RnbHUi
Hi guys
Today I finished checking FIRMWARE 20180124
1: It works well all
2: Quick start
That I do not like it
1: The same as before, you can not make backup copy with the original program itself
2: It has screen backgrounds that do not work
3: Connecting a mobile with MTP option does not work
My opinion: leave the ROM (FIRMWARE) free to move the APP as we want and surely that MX96 wins many fans
Thank you
2: Quick start
Thank you
thanks for your suggestions.
we will transfer your message to our supplier to improve it.Coupons Updated Every Day: https://bit.ly/2RnbHUi
I don't know what's going on. I've loaded 102, 124, 211, 502, 525, 526, 721 and a few ROM's from different boxes. Some will start and some wont go past the H96MAX page. The ones that start have no WiFi, the WiFi button does nothing. Searching around the forums I see there are other people that have this same problem. My WiFi chip is stamped LTM8830, searching the net on this chip it says it's based on the 9377. I've had this box a year and it came with 7.1. The tags say 20171219 and 4G+32G+9377
Originally posted by netconn View PostI don't know what's going on. I've loaded 102, 124, 211, 502, 525, 526, 721 and a few ROM's from different boxes. Some will start and some wont go past the H96MAX page. The ones that start have no WiFi, the WiFi button does nothing. Searching around the forums I see there are other people that have this same problem. My WiFi chip is stamped LTM8830, searching the net on this chip it says it's based on the 9377. I've had this box a year and it came with 7.1. The tags say 20171219 and 4G+32G+9377Coupons Updated Every Day: https://bit.ly/2RnbHUi
Got it working... I was using the v1.39 loader all this time and getting nowhere. For some reason I decided to try loading 502 with v1.52 loader and the box booted right up and works fine.I don't know what the difference is between v1.39 and v1.52 but I guess some part of the firmware didn't load with v1.39...
There are currently 2934 users online. 0 members and 2934 guests.
