A New Stock Rom Firmware for H96 Max RK3399
    Originally posted by nyceyes View Post
    Does it take that long? I guess I will try it. Thanks for the suggestion.
    It wont boot even if you wait 1 year!
    Max 5 minutes is enough for boot up,more than it means failure!
      The boot problem could be due to the failure of the stock 5V 2A power adapter. Try to plug in the A-A cable via the USB 3 port using a 2.4A USB charger, see it boots up. This works for me.
        Originally posted by xShARkx View Post
        For what i know, the rockchip batch tool is an older version of the factory tool, and i used the factory tool to do the update!
        Here, these are the lasted versions:
        Driver Assistant v4.5
        http://geekbuying.mediafire.com/file...itant_v4.5.rar
        Factory Tool v1.45e
        http://geekbuying.mediafire.com/file...ool-v1.45e.rar
        Try these, they worked with me!
        I tried using this tool last night on my h96 max rk3399 but when it opens it doesn't show which port to use , I tried over 20 times and the same thing , it open's up but no port number ,does anyone know why ? thank you for any info . also the reason I am trying this is because I have no wifi ,nothing and I just got this box .
          i need firmware (Rom) Android TV for box H96 Max
            Hey guys, Glad to share the firmware for H96 MAX RK3399 TV Box PC Flash Firmware Flash Tool Driver Assistant Flash guide, please refer to: H96 MAX Upgrade All Steps Have […]
              i need Rom Google TV 7.1 or 8.0
                Then you bought the wrong device, because this device runs tablet firmware.
                Only Mibox, Nvidia Shield or Google Nexus Fugu devices run AndroidTV 7.1 and some tv's from Sony & Phillips.
                  Should we learn this?
                    That is for Amlogic and it's not Google Certified, this box is Rockchip and works different.
                    Rockchip has AndroidTV Oreo but manufacturers must license it with Google and pass CTS/GMS tests.
                    Firmware is then encrypted and protected and can only work on the manufacturer's device that link with Google.
                      Factory Tool v1.45e
                      Hello,
                      How can I reinstall this firmware using a USB? Is it possible? Thanks
                        Originally posted by diyako4 View Post
                        Hello,
                        Hi ,
                        you must use a PC to flash this Rom .
                        gefattern
                          thanks for info
                            Hi ,
                            gefattern
                            BTW, can flash be done using window 10 or a 7 is a must?
                              Hi ,
                              no you can use Win10 for sure , as possible use newest Drivers & Tools ,
                              if any Problems ask ,
                              greetings / gefattern
                                Hi ,
                                I really appreciate your help. are the drivers and tool available on geekbuying the newest ones?
                                Cheers
                                Diyako4
