Trouble Again.
H96 Pro + unable to flash
@mujeebas
du hast meinen Beitrag gelesen ? -> http://freaktab.com/forum/tv-player-...cked-need-help
da es sich um genau das selbe board handelt !
ich habe mehrere/viele Firmware probiert, es ging nur diese eine, aml_7.1_s912_q9377-H96PROPLUS_LP_KDMC_mac-20171010.img
mit einer anderen brach das flashen bei 4% oder 8% ab
wichtig ! auch wenn das Burning Tool "DingDong" macht ... laufen lassen bis es tatsächlich abgebrochen wird oder fertig meldet
you have read my thread? -> http://freaktab.com/forum/tv-player-...cked-need-help
because it is exactly the same board !
I have tried several / many firmware, it was only this on, aml_7.1_s912_q9377-H96PROPLUS_LP_KDMC_mac-20171010.img
with others the flashing stopped by 4% or 8%"
important ! even if the Burning Tool makes "DingDong" ... let it run until it is actually canceled or reports readyLast edited by Cju; 25 February 2018, 16:28.
Many Thanks Success again with pin short method flash with ...aml_7.1_s912_q9377-S912_LP_mac-20171206.
cju given link not opening http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s912/alfawise/708834-h96-pro-plus-bricked-need-help
ch3mn3y has already given you that ... at the top -> https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g!prxFnCRA
or here -> https://www.chinagadgetsreviews.com/...-tv-box-2.html
I hope that is the right one ... after unpacking
Guest
mujeebas Hi, can you solve your box problem? What method did you use? You could share, I'm exactly with the same problem that you described.
Description my Box:
Aml - S912
Revision - r0p4
ROM - 32 GB
RAM - 3 GB
Wifi-Chipset - 9377
Android 7.1.2
mac-20171129
Label:
cz-s32-v5
KIB 20171207
3 + 32/9377
PCB:
S32-V5(LPDDR3)
2017-09-29
FIRMWARE ORIGINAL:
aml_7.1.2_s912_q9377-H96PROPLUS_LP_mac-20171129
There are currently 2266 users online. 3 members and 2263 guests.
