Oma Rocks CX-919 ROM (Android 4.2.2)
Originally posted by smithmal View Postedit: not ready for prime time yet... no image following boot.
I am downloading now, and will be testing this weekend.
I have yet to run logcat on the CX-919, but we will be in the dark without the logcat.
To use logcat you will need ADB. If you do not know what either is, google it ( I do not want to post links and break a forum rule ) .
Once you have ADB its easy as running this simple command to log to a file.
Code:adb logcat > CX919LOGCAT.txt
"Talk is cheap. Show me the code." - Torvalds, Linus
Great!
I have yet to download / flash.
How did you go about flashing?Did you use the finlessflashtool? Which kernel was used ?
Screenshots?
On another note I've been thinking of ways of using the CX-919 on my laptop (for more convenient debugging) .
The only way I can think of, is running a VNC server on the CX-919 and using a VNC Client on the laptop.
I'll post my results"Talk is cheap. Show me the code." - Torvalds, Linus
OK I will bite..... What's this all about?
Something I can do to help?
Well I have noticed a problem, i cannot for the life of me get the /sdcard to mount while using this rom, either in cwm or in android itself.
Finless, Oma over on XDA created a port of his oma rocks rom for the cx-919 however there seems to be some issues with it, it's in this thread here on post #511 http://forum.xda-developers.com/show....php?t=2310818
Originally posted by sam321 View PostI am 99.98% sure that I can get everything working on the CM10 ROM what is Oma7144 policy on porting ROMs. Is he a nice guy to deal with ???
I had asked him if there was a chance for a port and basicly he just suggested that all that was needed was another kernel and a different wifi module to be loaded, so I don't think he'd have a problem with it.
He has several roms , one being the CM10. When asked to port for the cx-919 thought he would of ported AOKP or CM .
Hop on the thread mentioned above and check em' out."Talk is cheap. Show me the code." - Torvalds, Linus
Originally posted by cityhunter View PostWell I have noticed a problem, i cannot for the life of me get the /sdcard to mount while using this rom, either in cwm or in android itself.
Typically all Oma ROMs require patching the ROM with his NAND_Fix Patch. Generally using the RKBatchTool, you flash the ROM and then it immediately boots into CWM. From there, you flash the patch file. The easiest way to do this is to copy it to your external SD card, and then navigate to it within CWM and flash.
Can anyone tell me what kernal they are using with this ROM successfully. Also, it would be nice to know which ones have been tried so far.
BTW, you can obtain the NAND_fix patch file from here.No need to unzip, you need to flash it as a zip file.
smithmal
Screenshots?
There are currently 3195 users online. 2 members and 3193 guests.
