2018 firmware for H96 Pro+
alexchiu
It's totally different. You have official firmware now and SCV7A is unofficial one. However older than 20180409 I believe it's better firmware. And as You have S32-V5 or V6 You may move to superceleron's rom. However it's Your choice.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Sir, what is the diffrence in between these two roms ( https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g!hzJAHSJQ )
Originally posted by surjeetdh View PostSir, what is the diffrence in between these two roms ( https://mega.nz/#F!8qhRRaYJ!2ZA3VLjv...TF27g!hzJAHSJQ )
H96 Pro+ Firmware Fixed Uboot Power On Libreelec/H96 Pro+ Firmware CZ-S32-v2.2-v3/aml_7.1.2_s912_q9377-S912_mac-20180409_H96PROPLUS_LOGO_ubootfix_792Mhz.7z
H96 Pro+ Firmware Fixed Uboot Power On Libreelec/H96 Pro+ Firmware CZ-S32-v2.2-v3/aml_7.1.2_s912_q9377-S912_mac-20180409_H96PROPLUS_LOGO_ubootfix_816Mhz.7z
Hello
I bought the Alfawise H96 Pro + 3gb / 32gb
I had a problem where it crashed and then it did not work anymore.
The SD procedure does not work because the box hangs and pops the screen image
I did the restore by PC with USB cable using the following FW:
aml_7.1_s912_q8723bs-H96PRO_dongle_LP_KDMC_mac-20180120
Only unfortunately my wifi, bluetooth and LAN is not working ....
When I turn on the wifi it turns off by itself
The bluetooth is "on" but in the color disabled and without detecting anything
And nothing works over the internet LAN
Anyone know what I can do?
I'm very new to it and I do not understand many things.
What FW can I use to fix it? Thank you !!!
Sorry for english... google translate...
It may be violent, but open the box.
Green /black/ motherboard - normal version /kdmc/
Blue - LP version
If You have green, you can try my version firmware. IPTV in Kodi play great, the box is not so hot. https://drive.google.com/open?id=1cg...g3AE1rKN83CO7T
Blue - LP version
I just got the gearbest, it's still in the initial Warranty. I believe I will not open, can I? Is there any problem of trying the firmware without opening and anything back to previous?
There are currently 2469 users online. 4 members and 2465 guests.
