MVR9 RK3328 LibreELEC Release
    LibreELEC is a Kodi Linux OS with much improved video playback and lower CPU and memory usage compared to Android.
    Instructions to run it
    1. Connect a micro-sd card with a card reader to your PC.
    2. Make sure the micro-sd card is formatted, right click on the drive letter in My Computer and choose format, try Fat32.
    3. Download the LibreELEC image and unzip the gz file with 7zip so you are left with a .img file.
    4. Use Etcher app(https://etcher.io/) to load the image and flash it to the micro-sd card.
    5. When it completes, insert the micro-sd card into your tv box that is turned off.
    6. When turning it on, it will boot to LibreELEC.
    7. To use Android normally, just remove the micro-sd card and insert and reboot when wanting to run LibreELEC.
    Features
    - Supports mpeg2, h264, h265, vp9 hardware decoding
    - Supports deinterlacing for h264, mpeg2
    - HDR Support
    - IR Remote Support
    - HDMI CEC support
    - Bluetooth support
    - PVR support
    - Netflix, Amazon Prime Video addon 960x540p and 720p software decoding support(still being improved)
    Netflix addon
    Inputstream based Netflix plugin for Kodi. Contribute to asciidisco/plugin.video.netflix development by creating an account on GitHub.
    Prime Video Addon for Kodi Media Center. Contribute to Sandmann79/xbmc development by creating an account on GitHub.
    Latest PVR and Libretro games addons
    TVHeadend is called pvr.hts
    After installing Netflix or Amazon Prime Video, install InputStream addon from the LibreELEC repo.
    In the InputStream addon's settings change max decoder and secure decoder resolution to 720p.
    Then you will be able to watch smooth HD video for these streaming services.
    To use bluetooth:
    Check that bluetooth is turned on in the LibreELEC Settings.
    Then change the default HDMI Sound output to Pulseaudio Bluetooth to get sound over your bluetooth speakers or headphones.
    Set the resolution to 1080p@60hz in Display Settings on a 4K tv for better performance.
    Changelog:
    - Switched bluetooth on by default
    - Dirtyregions 1 for a little lower CPU usage
    - Unknown sources for addons enabled by default
    - Expert mode settings enabled by default
    - Send noise audio setting disabled
    - Improved GUI speed
    - PVR addons added, just enable the one you need
    - Fast channel switching for SD, HD 25/50hz
    Download links:
    For MVR9 with orange/red D-Pad remote
    https://mega.nz/#!kUMwGYJS!pbVT2TVEr...QfzJo62kUK6xzc
    Update: 03 Feb 2019
    For MVR9 with numbered 0-9 keys ir remote
    https://mega.nz/#!wYEyEQKZ!XcfyTtvb1...Zt-BL3px5Xk00c
    Update: 03 Feb 2019
    In and running looking good,
    Video quality and playback not to bad Plays well on most fiels tested
    Note problem with Remote
    Pairing with Bluetooth Speaker, does not find Bluetooth at all.
    Blinking led interesting
    Nice
      RC doesnt work, but HDMI-CEC
      23,976fps playback without judder, but every 5 or 10 minutes audio interrupts (MKV with AC3, settings: hdmi passthrough and ac3 transcoding)
      other fps and ac3 transcoding to be checked in the next days
      the blinking LED is annoying during playback, can this be changed?
      not sure if upscaling to 4k is enabled (changed display resolution in Kodi but its only for the GUI, right?
      when power off libreelec, i cannot power it on again with RC. need to replugin power cable
        Hi
        I'll be building my own optimised LibreELEC today/tomorrow.
        Hope it will work better
        A whole new IR remote driver needs to be developed.
        If I can get the correct keycodes for Linux, I might be able to do it myself.
        I'm very impressed so far with what LibreELC can do in the few months it was developed for Rockchip devices.
        I think you need to disable HDMI pass-through if using a soundbar with optical connection to tv.
        Maybe 3-5 options can help?
          looking forward for your version :-D
          i would just need the RC to power on the box after libreelec was powering it off, even power button does not work.
          the alltime blinking LED is very annoying :-D
          well, on android with RKMC i have no sound issues, but will check with disabled passthrough.
          edit:
          also with passthrough disabled, i have the audio interrupts
          log file with passthrough, stopped playback after audio interrupt
          log with disabled passthrough
            New version 20180313
            -Addon support
            -Install unknown addons enabled by default
            - PVR/DVB support
            -Show hidden files/folders by default
            -remove reduce freq call in vcodec
            -remove hdmi 4k 50/60hz limit
            -use 933MHz ddr blob if it exists
            I spend over 2 days trying to build it.
            Netflix 720p
            Go to Addons - Install from repo - RB Add-ons repo - Videoplayer Inputstream
            Enable both addons
            In Inputstream.adaptive addon settings change maximum and secure resolution to 720p.
            Install the Netflix repository
            Install the Netflix addon from that repository
            https://github.com/kodinerds/repo/ra...flix-1.0.1.zip
            Go to File Manager
            Add a new location - Root folder and give it a name
            Go to /storage/.kodi folder
            Long press with an airmouse and release then create a new folder called 'cdm'
            Copy the libwidevinecdm.so file over to the storage/.kodi/cdm folder from the left pane window to the right one by long pressing on the file.
            https://mega.nz/#!RFEmUCbY!ka1gDI7Rg...ZheUzK0kgmhlKI
            Exit and in the power menu choose reboot to refresh the new settings and files.
            Open the Netflix addon and play 720p streams.
            It still needs a bit of work and Netflix 720p can be smoother since it plays software decoded but with the next 1 or 2 RK patchset merges, LibreELEC should run much better.
            Link:
            https://mega.nz/#!tIVhmBRR!3akkoTTXd...b-OeJtHvO5Iwec
            Password: mvr9
            WinSCP app on a PC is like the Teamviewer for LibreELEC
            You can copy/delete files/folders and gain access to your LibreELEC device from a PC.
            WinSCP is a popular free file manager for Windows supporting SFTP, FTP, FTPS, SCP, S3, WebDAV and local-to-local file transfers. A powerful tool to enhance your productivity with a user-friendly interface and automation options like .NET assembly.
              Password added.
                Looking ok so far, stumbled thru not a big user of Kodi but as written does the, Good work
                  is it not possible to fix this two points or normal behaviour?
                  -when power off libreelec, i cannot power on the box with RC / power button. need to remove power and plug in again.
                  -blinking LED (if using CEC its okay and i turn around the box :-) )
                  using no addons or streaming, so can`t say anything about.
                    The IR Remote driver is in development, it has to be done from scratch, can't use the Android way.
                    I'm not sure how long it will take but it should be soon as it's not a complicated thing like video playback or wifi drivers.
                    LibreELEC is very strict on how changes must be done before they include it.
                    I see there is a new patch that should be included in the next LibreELEC that adds lots of game controllers like PS4 and others that use wifi dongles too.
                    The blinking LED, I will check if I can fix it, should be a very small change.
                    Then it can stay on always or be completely off.
                      okay, so i have to be patient
                      cool, an option for the LED, great !
                      regarding the reboot when i push stop button on CEC, i will monitor further
                        HI
                        Here is a new version.
                        - Fix LED blinking, now it is blue and on like on Android.
                        The ir remote will be fixed in 1-3 days.
                        Bluetooth support also needs to be added.
                        Then everything will work and then it's up to LibreELEC and RK driver updates to fix or improve things.
                          hi mo,
                          cool, LED looks nice now :-D, well done !
                          in the initial Version there was an option in LE to configure devices (e.g. CEC), now hided or removed?
                          when the ir remote is solved and the power on works, then LE is the best solution for me.
                          reboot after pushing stop button via CEC still exist, not a problem when using OS Menue and stop layback
                          looking forward when my audio issue will be fixed :-)
                            tried last test build from today and it seems after short test my audo issue is solved with delay after refresh rate set to 6.5s
                            no more crashes after pushing stopp button
                            still not working:
                            IR (power on the box)
                            blinking LED
                              still not working:
                              blinking LED
                              Hi
                              Where do you download the latest test build?
                              Is it this one or newer? - http://test.libreelec.tv/LibreELEC-R...ox-trn9.img.gz
                              You can just replace the dtb file with mine(from here http://freaktab.com/forum/tv-player-...034#post715034) after inserting the card reader back into the PC.
                              I'll upload the file and send to you to fix the LED.
                              It will show you an Image, dtb file and a system.
                              The LED is an easy fix and is blinking on all devices, with LibreELEC 9 alpha they are suppose to fix it soon for all devices.
                              The IR remote driver for Firefly is finished but Kwiboo didn't merge it it.
                              The same driver with slight changes should then also work for MVR9.
                              It seems there will be lots of development for LibreELEC 9 but it doesn't move as fast as Kodi 18 development.
