1080P Nexus Kernel for SDK2 Strauzo ROM
    Hi, ..
    can i flash Minix X7 - ROM Nexus SDK2 and Multi-Windows
    and just drop and replace this kernel 1080p in the path before flashing:
    Minix X7 Nexus SDK2 MultiWindows 1.2\rockdev
    IF not how flash the kernel?!
    I see various kernel in this topic, which must i use for get 1080p and performance game experience?!
    BIG THX!!!
      Not so over-clocked kernel
      Originally posted by SpicyBoy View Post
      Yep i'm with you..
      I have waited the long time. Then I made it self -
      Sad_kernel_for StrazoFirmware_cpu1608h_gpu600_ddr667.img.
      If it interesting somebody, you can get and test it:
      https://mega.co.nz/#!SFdWkQxB!I2CzOAHTe1CgnRe8wQblsX5t0ZIu_BxDrXQHUo_qX0U
        First of all thx, did you check it allready?
          TESTED
          Yes, it's OK. Few days it's working with no any problems.
            Yes! The sad kernel makes me very happy Thank you!
            I use a regular PC monitor not a TV, so all 720p kernels look very poor/fuzzy. And as many have noticed, the resolution is wrong on the Finless kernel (1920x840 instead of 1920x1080). The sad kernel is just right, 1920x1080 beautiful. I have not tried lots of video yet but it doesn't matter too much to me anyway, I use this for a regular computer a lot so more important to have a clear display than to have perfect videos.
            PS Bob Finless if you notice this, I think you misunderstand the resolution problem in your patched rom in the OP. It is not the top and bottom bars problem in this case, not a problem of squished or too fat, too wide. Or maybe that is a problem too, but the big problem here is that the vertical resolution is 840 so things are streched, skinny, too tall. You mentioned once that you could try making it 1920x1120 to fix fatness.. but really just need to make it 1080 instead of 840 to fix the tallness not the fatness.
