1080P Nexus Kernel for SDK2 Strauzo ROM
    Originally posted by trungk43 View Post
    How long does it take for message MINIX? for the first time reboot it is about 2 minutes.
    You can try the pre-006 stock version at http://minixforums.com/threads/pre-006-firmware.2390/
    I also created a OC kernel for 1080p resolution https://www.dropbox.com/s/3s4hpslo1z...800_vsfsam.img
    Trung
    Trung
    Am i missing something? Trung, open a topic mate, seems like you have made some effort to just post it around . I will try your kernel today, i have this doubt that we will never settle down with this device.
      Re: 1080P Nexus Kernel for SDK2 Strauzo ROM
      Trung
      Trung
      Has that not got the VSAM fix which is incompatible with Strauzos ROM?
      Sent from my Firefly V65 using Tapatalk 4
        Installed this rom with trung kernell but have no sound? Why is that?
          No sound with 3.5mm output? No sound with usb? or both? I'm using Trung's kernel and use 3.5mm and it works fine. I haven't tried the usb out.
            I can not get any sound true hdmi with this thung kernell, why is that? Is it something in settings. If i use 3.5 i have sound but not if i use hdmi.
              have you tried different hdmi cable. It seems like some problems are caused by the cable you use (I useed to have shutdowns before I changed the hdmi cable I was using)
              "Success is a lousy teacher. It seduces smart people into thinking they can't lose."
              - Bill gates
                Originally posted by diegocaxudo View Post
                have you tried different hdmi cable. It seems like some problems are caused by the cable you use (I use to have shutdowns before I changed the hdmi cable I was using)
                Yes i habe tried different hdmi cable same result. Will try to flash new kernell and se if the problem is still there.
                Flashed a new kernell and i have sound again. This is strange.
                Maybe Thung kernell and finless don´t match.
                  You may want to check out post 49 on this thread.
                  To switch audio use the free app from google play SoundAbout
                  if you like the old tabletui you can set this in build.prop (status bar at the bottom)
                  for HDMI passthrough you must swap only two lib (in other thread you can find this libs)
                  many new tv scale automatically the rom you don't need hdmi zoom, (es. for Samsung TV the button P-size on remote control) but if your tv not scale well with menu options, you can use this command:
                  echo 95 > /sys/class/graphics/fb0/scale
                  (thanks sam321 for this)
                  i suggest to change the number 95 from 90 to 100 to find your best fit. when you have your number you can add a script in init.d folder to do the scale automatically at boot time
                  the rom work already in landscape mode and start in landscape mode. If you have problems because you have started an app the force the display in portrait, use the already installed app rotation lock, set in landscape mode and after on top right status bar click on rotation lock 2 time. the final position of the icon inside the top right status bar must be rotation locked.
                  All can help me to add other options to this very very good base pure android rom.
                    I have no audio either after flashing thungs kernel. Changing settings to hdmi audio in soundabout did not help...
                      Originally posted by jankdc View Post
                      After flashing this rom with both finless and trungk43's kernel, I am unable to connect to my window's pc. I want to backup and restore my apps. Anyone have any ideas on what needs to be done? Thanks!
                      More info: I am using moborobo and the instructions here. I have usb debugging enabled. I am unable to see usb under settings/device nor am I able to see a connect to pc option anywhere in the settings.
                      I am able to enter into flash mode and connect to the pc that way.
                      I would appreciate any help.
                      Thanks!
                      Please try this link http://www.dummies.com/how-to/conten...r-nexus-7.html
                      --Sorry, not working
                        I created a new kernel based on Finless 1.5a kernel_stock_1080.img, using this tool http://www.freaktab.com/showthread.p...-rk3188-kernel!https://www.dropbox.com/s/t5w5efliqm...800_vsfsam.imgIt works fine with Minix X7 Nexus SDK2 MultiWindows 1.2- Ethernet and remote control work fineTrung
                        This dropbox link is unavailable now.
                          Updated link
                            trungk
                            trungk43, could you make the same kernel, but not so overclocked (like this cpu1608h_gpu600_ddr667)?
                            Thanks!
                              Hi, ..
                              can i flash Minix X7 - ROM Nexus SDK2 and Multi-Windows
                              and just drop and replace this kernel 1080p in the path before flashing:
                              Minix X7 Nexus SDK2 MultiWindows 1.2\rockdev
                              IF not how flash the kernel?!
                              thx advance
                                Thanks!
                                Yep i'm with you..
