Sent from my Firefly V65 using Tapatalk 4
T428 kernels with video fix and overclocks
Recap... also posted this in my 5v 10a power thread
I ended up using an old 350watt PSU. I took a molex to sata power adapter, cut it and spliced it to become a molex to micro USB (power only). Then shorted the green wire and a ground on the 20 pin to power On the PSU when I flipped the switch.
The 5v rail has 32amps, more than enough power for this stick. I'm not getting any reboots anymore that's for sure. Now I can benchmark my stick while OC'd. I'm going to find a way to clean it up and make it look nice. Probably remove all the extra cables and such. Maybe leave 1 or 2 molex for external devices if need be.
Power
Stick
Benchmark Now benching 3000 points higher than my Galaxy Note II!
Right now the stick is
Nexus 7 Multi-Window ROM v1.2
OC Kernel CPU @1.6GHz (stick would still reboot when trying to run the 1920MHz clock speed) Performance / noop, GPU 789MHz, DDR 720MHz
vram heatsinks on the NAND, Memory, and Processor
10mm fan on CPU solderd to the 5v and ground from the USB (A) port
The only issues I am having right now are that I get no video on my PS1 emulator. I get audio, and can load a save state, but just a black screen. I also now get FCs as I try to load up a ROM from my N64 emulator. Im not sure if its the ROM or the Kernel causing the issue. I upgraded from the Multi-Window v1.1 and Stock kernel at the same time, so not sure witch one is to blame. It could be they just dont like 1080p.
Video playback at 1080p is flawless. Even on WiFi. I have watched 1080p, 720p and 480p Movies/TV shows and have no stutters, skipping, or buffering. Having this type of performance on this stick at full 1080p is fantastic.TV Stick: MK808 // Tronsmart T428
ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
Recovery: ClockworkMod
Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
Phone: Samsung Galaxy Note II
ROM: Whompasaurus v4.2
Kernel: Persus
Video is malformed message
I am using jjhmod-v2.2 with a 1080 kernel built using marvin - "1080p cpu1800h ddr720 gpu600o vsfsam" (with config modified to allow only 1200 MHz and 1608 MHz). With this when playing an online source, playback stop consistently after about 10 mins, both with Wondershare Player and MX Player. Logcat with wondershare is below. Playback stops with a "Video is Malformed" error. Any ideas ?
09-05 12:18:00.542 D/PlayerActivity( 1017): Play from extract application, path is http://85.12.5.84:8777/bapyniilhcie2...kdle/v.mp4.flv
09-05 12:18:00.542 D/PlayerActivity( 1017): onStart
09-05 12:18:00.542 D/PlayerActivity( 1017): onResume
09-05 12:18:00.552 D/PlayerActivity( 1017): Get playlist current index is 0
09-05 12:18:00.562 D/PlayerActivity( 1017): onResume CreateMediaPlayer
09-05 12:18:00.562 D/PlayerActivity( 1017): Create MediaPlayer
09-05 12:18:00.692 D/libEGL ( 1017): loaded /system/lib/egl/libEGL_mali.so
09-05 12:18:00.692 D/libEGL ( 1017): loaded /system/lib/egl/libGLESv1_CM_mali.so
09-05 12:18:00.692 D/libEGL ( 1017): loaded /system/lib/egl/libGLESv2_mali.so
09-05 12:18:00.722 W/BufferQueue( 95): freeAllBuffersLocked called but mQueue is not empty
09-05 12:18:00.782 D/OpenGLRenderer( 1017): Enabling debug mode 0
09-05 12:18:00.792 D/MediaPlayerManager( 1017): !!!surfaceCreated
09-05 12:18:00.792 D/MediaPlayerManager( 1017): !!!surfaceChanged
09-05 12:18:00.792 D/MediaPlayerManager( 1017): Video surface is ready, dispatchMessage SURFACE_READY now
09-05 12:18:00.792 D/MediaPlayerManager( 1017): call createMediaPlayer_l
09-05 12:18:00.792 D/MediaPlayerFactory( 98): createPlayerlayerType=7
09-05 12:18:00.792 I/MediaPlayerFactory( 98): create FFPlayer
09-05 12:18:00.882 I/ActivityManager( 349): Displayed com.wondershare.player/.PlayerActivity: +918ms (total +1s549ms)
09-05 12:18:00.892 I/FFMpegMediaPlayer( 98): setDataSource in 0x417c6060
09-05 12:18:00.892 I/FFMpegMediaPlayer( 98): ******************************************
09-05 12:18:00.892 I/FFMpegMediaPlayer( 98): starting main player thread:2013-7-1
09-05 12:18:00.892 I/FFMpegMediaPlayer( 98): mCurrentState = 1
09-05 12:18:00.892 I/FFMpegMediaPlayer( 98): setDataSource(http://85.12.5.84:8777/bapyniilhcie2...kdle/v.mp4.flv)
09-05 12:18:00.902 E/FFMpegMediaPlayer( 98): ffmpeg version 7-1
09-05 12:18:01.152 E/FFMpegMediaPlayer( 98): new mHostname=85.12.5.84
09-05 12:18:01.182 I/ActivityManager( 349): No longer want android.process.acore (pid 701): empty #17
09-05 12:18:01.372 I/FFMpegMediaPlayer( 98): mpegts_probe get probe score: 100
09-05 12:18:01.392 E/FFMpegMediaPlayer( 98): avformat_open_input:read_header
09-05 12:18:02.172 E/FFMpegMediaPlayer( 98): Hery, s->iformat->name flv
09-05 12:18:02.172 I/FFMpegMediaPlayer( 98): prepareVideo
09-05 12:18:02.172 W/MediaPlayer( 1017): info/warning (701, 0)
09-05 12:18:02.172 I/MediaPlayer( 1017): Info (701,0)
09-05 12:18:02.212 I/rkffplay_version( 98): rk30 board found in platform property
09-05 12:18:02.212 I/FFMpegMediaPlayer( 98): prepareAudio
09-05 12:18:02.212 I/FFMpegMediaPlayer( 98): prepareSubtitle
09-05 12:18:02.212 I/RkAudioPlayer( 98): mAudioSink->open in mSampleRate = 48000 channels = 2
09-05 12:18:02.272 E/FFMpegMediaPlayer( 98): start in mCurrentState in
09-05 12:18:02.272 E/FFMpegMediaPlayer( 98): start in mCurrentState = 8
09-05 12:18:02.272 D/AndroidMediaPlayer( 1017): duration is 7776852
09-05 12:18:02.302 D/MediaPlayerManager( 1017): !!!surfaceChanged
09-05 12:18:02.312 D/MediaPlayerManager( 1017): ++++send MEDIA_PLAYER_READY message
09-05 12:18:02.312 D/PlayerActivity( 1017): Playing ...
09-05 12:18:02.322 I/ ( 98): starting thread
09-05 12:18:02.322 D/AUDIO_DECOE( 98): prepare()
09-05 12:18:02.322 E/FFMpegMediaPlayer( 98): Hery, FF_MediaPlayer::BufferingPlayer
09-05 12:18:02.322 D/PlayerActivity( 1017): MEDIA_PLAYER_READY
09-05 12:18:02.322 D/PlayerActivity( 1017): Title changed 0
09-05 12:18:02.402 I/avcdec ( 98): avcdec init status 0x0
09-05 12:18:02.412 I/avcdec ( 98): Width 848 Height 352
09-05 12:18:02.442 I/FFMpegMediaPlayer( 98): network case: mVideoWidth = 840, mVideoHeight = 352, tmpframe->DisplayWidth = 840, tmpframe->DisplayHeight = 352
09-05 12:18:02.472 I/RkRenderer( 98): Width = 848,Height = 352
09-05 12:18:02.502 W/MediaPlayer( 1017): info/warning (702, 0)
09-05 12:18:02.502 I/MediaPlayer( 1017): Info (702,0)
09-05 12:18:03.702 D/UPNP_RemoteControl( 1017): callback event id: 1027
09-05 12:27:38.172 I/VIDEO_DECOE( 98): Video is malformed
09-05 12:27:38.412 D/AndroidMediaPlayer( 1017): Hardware decoder completion
09-05 12:27:38.412 D/PlayerActivity( 1017): Playback reach end
09-05 12:27:38.412 D/PlayerActivity( 1017): Finish it!
09-05 12:27:38.442 D/PlayerActivity( 1017): onPause
09-05 12:27:38.462 D/MainActivity( 1017): http http://85.12.5.84:8777/bapyniilhcie2...kdle/v.mp4.flv
09-05 12:27:38.472 D/DownloadService( 1017): onDestroy
09-05 12:27:38.472 I/UPnPService( 1017): from service destory
09-05 12:27:38.472 D/UPNP_RemoteControl( 1017): cmd: 3
09-05 12:27:38.472 D/UPnPService( 1017): send command +3 and callback is -1
09-05 12:27:38.472 D/RemoteControl( 1017): Release RemoteControl !!!!!
09-05 12:27:39.682 D/PlayerActivity( 1017): onStop
09-05 12:27:39.682 D/FlurryAgent( 1017): Ending session
Originally posted by BigND View PostMolle, can you share your .xml settings file for hardware accelerated XBMC? The file itself with all needed parameters. Thanks in advance!
Code:<advancedsettings> <video> <stagefright> <useavccodec>1</useavccodec> <usevc1codec>1</usevc1codec> <usevpxcodec>1</usevpxcodec> <usemp4codec>1</usemp4codec> <usempeg2codec>1</usempeg2codec> <useswrenderer>false</useswrenderer> </stagefright> </video> <network> <disableipv6>true</disableipv6> <cachemembuffersize>20971520</cachemembuffersize> </network> </advancedsettings>
Re: T428 kernels with video fix and overclocks
Originally posted by Spotopolis View PostI ended up using an old 350watt PSU. I took a molex to sata power adapter, cut it and spliced it to become a molex to micro USB (power only). Then shorted the green wire and a ground on the 20 pin to power On the PSU when I flipped the switch.
Power
Stick
Originally posted by BigND View PostThanks for quick reply. Another couple of questions. Does XBMC support DTS sound without external player? Where do i find XBMC builds with HD acceleration support?
XBMC releases and various builds for all platforms can be found here. All nightlies since the beginning of August and all test builds with 'libstagefright', 'hwaccel' or 'SF' in the file name support hw acceleration.
I'm currently using this version: 'xbmc-20130714-6ec63cd-adddroidlibstagefright-armeabi-v7a.apk'.Last edited by Molle; 06 September 2013, 18:51.
Originally posted by Trhuster View PostI tested your kernel on Minix X7 and finless 1.4 rom and got 22024p, not bad!
How did you get the temp sensor readings?
Originally posted by Batfink32 View PostWow! I'm going to flash that tonight. Are you using cooling? The fact the X7 is totally enclosed scares me to run it so overclocked.
Originally posted by Trhuster View PostBox is stock, i have not tested long term use. Temp reading is visible when you run stablity test, if it shows correct temp i have no clue about.
There are currently 2074 users online. 1 members and 2073 guests.
