T428 kernels with video fix and overclocks
Originally posted by hochoch View PostI'm pretty sure the wifi radios are different so it may not work. Could be wrong. Can't hurt to try though, let us know if you do!
Or overclock an existing kernel using:
http://www.freaktab.com/showthread.php?7150-patchomatic-tool-overclock-vsync-fix-any-binary-rk3188-kernel!
Originally posted by babnik80 View PostHi, with sam kernels, you said that lot of errors pop up on dmesg. I did a lot of reading, but active perl is still something strange for me. Can you provide us Sam's kernels with your fix, for use with mk802 iv? Thanks for everything!!
Can anyone help. device manager is good, "Found in flash tool, It counted to 2042, I flashed, no errors and finishes every time, then plug in 2.0amp note 2 charger, etc chargers for power and nothing on the video. I've done it a dozen times waiting at different times etc, etc. SD is out...I'm at a loss. I bought it in August. Tried flashing this 720p/1800/600 then even the basic Finless 1.5 sticky'd below it. Even the rockchip batch tool has a green box and flashed the upgrade tronsmart Rom with no problems
I was able to get the rom in this link to work no issues, but I don't think it's overclocked.
This is the custom rom which made for Tronsmart T428 quad core tv sticks, and it is not offical release by tronsmart or rockchip,it is made by strauzo, a great […]
I am running it through my HDMI receiver, no issues with stock rom though. It will upconvert
What Rom?
I flashed back recently to the 1.4A rom by Finless from the 4.4.2 he had out. not that there was anything bad going on with that rom, I just like the smoothness of the Android 4.1.1 on the T426. I saw that you remarked these kernels would work on any of the finless roms but I cant seem to get them to flash to this rom. Are these kernels compatible with the 1.4A or do I have to run the 1.5A or even go back to the 4.4.2 android? Thank you.
There are currently 3413 users online. 0 members and 3413 guests.
