The newest Chipset Amlogic S912 Octa-core 64-bit ARM Cortex A53 CPU up to 2GHz,S912 system is faster than S905X.Pairing with ARM Mali-T820MP3 GPU up to 750MHz,Support system running smoothly.
RAM 3GB DDR3,ROM 32GB EMMC Flash,which strengthen the running speed of the box,and you can store lots of favorite files. support ethernet 1000M, bluetooth 4.0,Dual WiFi 2.4G/5G,gives you AWESOME home theater and gaming experiences.
Android 6.0 Marshmallow,coupled with the rapid and stable configuration,you can access to the thousands of Android games and apps at the smoothly,Install your favorite apps and enjoy it!without any lagging or freezing.
H.265 decoding is more powerful than H.264,it can save half of the broadband resources,H.265+VP9 double ultra HD is more clear than H.264+4K. HDMI 2.0 up to 4K2K, perfect combination guarantees high standard decoding resolution and high speed playback. Support a variety of country's languages,meet your language needs.
Gesendet von meinem TA-1053 mit Tapatalk
Hi ,
if the Vorke Z6 Rom runs good , you can try some of the CustomRoms for Z6 , but be sure the Specs are the same .
