I have a box leelbox Q2 pro at power on and locked on boot mode I connected the box to the pc I tried to send this firmware LeelboxRK-8703-7.1nv3-kodi-1225 in the procedure hangs and tells me "prepare IDB fail" I do not know what do you advise me to do? and correct the firmware I use? thanks for your help
Prepare IDB fail
Prepare IDB fail
I apologize in advance with my English use the translator I have a problem that I can not solve I hope in your enormous abilities and preparation to solve my problem ...
I have a box leelbox Q2 pro at power on and locked on boot mode I connected the box to the pc I tried to send this firmware LeelboxRK-8703-7.1nv3-kodi-1225 in the procedure hangs and tells me "prepare IDB fail" I do not know what do you advise me to do? and correct the firmware I use? thanks for your helpTags: None
Originally posted by bruno1969 View PostI apologize in advance with my English use the translator I have a problem that I can not solve I hope in your enormous abilities and preparation to solve my problem ...
is it a RK3229 with SV6051P Wifichip ??? , did you "eraseFlash" before flashing the Rom ???
what kind of Tool did you use ???
greetings / gefattern
Originally posted by bruno1969 View PostI bought it on amazon from a "Mgaolo" supplier I do not think I can have the Stockrom, is not there a different solution?
if no other Rom fits , no , the Problem is , that the RK3328 until now has not the
best Rom support !!!??? You need a Rom that supports your Specs .
Maybe you can find it here :
There are currently 2614 users online. 1 members and 2613 guests.
