Sunvell T95Z PLUS 2Gb/16Gb firmware
Hi all, been a while since ive posted, ive recently updated my t95z plus to 7.1.1, i have noticed google play store makes me authenticate every time i use it, its like its not remembering what ive aready put in.....also i am after using sky go, i am unsure how to unroot hence the reason i need stock firmware? if anyone could point me in the right direction would be appreciated, or point out something i am doing wrongTags: None
Originally posted by jamiehaworth View PostIve upgraded to 7.1.2 now but still same problem with the google play store, also trying to unroot my device using supersu when i update the binary and tells me to reboot it just freezes at the t95z screen i have to unpower and power back on? anyone advice on fully unrooting?
reboot, hope...
If you just install supersu, you will have boot loop! Install again the rom with flash tool! I had the same problem in the past. Now if you have to unroot the device you must flash twrp recovery first and (I don't remember in which forum I founded) install an unroot zip.
If you want give a try to this rom it's a little better and there is not problem with Playstore https://forum.xda-developers.com/sho....php?t=3751720
(sorry for my bad English I wish I will help you)
Originally posted by antouaa View PostIf you just install supersu, you will have boot loop! Install again the rom with flash tool! I had the same problem in the past. Now if you have to unroot the device you must flash twrp recovery first and (I don't remember in which forum I founded) install an unroot zip.
Thank you. I´ts excatly what I did today, trying to run some Samba server (SambaDroid). Now. goingo to Poison ROM.
Thank you. I´ts excatly what I did today, trying to run some Samba server (SambaDroid). Now. going to Poison ROM.
There are currently 2191 users online. 3 members and 2188 guests.
