Any Flash is a risk..so beware ...or tweak it till you break it.
April Firmware 2018-04-09 for Regular and L.P. memory - Untested
H96 -pro
Amlogic / q9377 / q9377: 7.1.2 / NHG47L / 20180409: user / test-keys
ATTENTION! All that you do with your box, you do at your own peril and risk!
Firmware for boxes with ordinary memory:
aml_7.1_s912_q9377-S912_mac-20180409 - FEX
aml_7.1_s912_q9377-S912-XGO_mac-20180409 - FEX
Firmware for boxes with LP memory:
aml_7.1_s912_q9377-S912_LP_mac-20180409 - FEX
aml_7.1_s912_q9377-S912-XGO_LP_mac -20180409 - FEX
Just tried aml_7.1_s912_q9377-S912_mac-20180409 from SD card on Gearbest Wiadom board 2017-02-10 H96-S912-TVBOX(DDR4)-V0.2
First it showed Upgrading, after about a minute my TV showed "Check signal cable" I left it for 1 hour in case it was still upgrading...it wasn't...took out the SD card and tried to boot, nothing, no LED, no boot.
Tried to get back.
Was running aml_7.1_s912_q9377-S912_mac-20171206, with few errors and yesterday I installed the S912_H96_3G_DDR34_171120_MAC, this is Wisdom ROM, it gives some Bluetooth share and System UI errors at times. Also some apps are declare failed but click wait and they usually work right. Anyway, after burning SD cards with bot versions of ROM, they would each get to about 95% and stop, I figured I was now the owner of a brick.
I switched to the USB burning tool, version 2.0.8 with the new aml_7.1_s912_q9377-S912_mac-20180409 ... success and like Shonk said, wallpapers are working now. So far there have been no errors, standby from the remote works too but the remote won't turn on the box if it is shutdown, red light comes on, have to cycle power to boot it.
Finally, working good so far on this Wisdom board.
HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
Does someone have a link for the firmware listed as Amlogic / q9377 / q9377: 7.1.2 / NHG47L / 20180409: user / test-keys , aml_7.1_s912_q9377-S912_mac-20180409 - FEX .
The link does not work!
Also where can I get a working TWRP for the " Wisdom" board?
I have tried a few using TWRP app to install but none worked for me.
Thanks.
You can use TWRP from superceleron's rom. It will work as rom memory seems to have same setup on all H96 Pro+ devices.
It can be taken from OTA's zip or here: https://mega.nz/#!Ji4iEAjI!5iCbS2F9J...cO6-MWb1b-z90IALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Thanks.
HK1 Pro Plus
FlowFon F1
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by soldiaz View PostFlashing MAGISK ended in bootloop..
I own an H96 PRO 2/16 q9377. Cannot find firmware, best would be OTA since I won't loose userdata.
Do I have to care bout DDR types?
Can anyone point me to download place?ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There are currently 3963 users online. 1 members and 3962 guests.
