April Firmware 2018-04-09 for Regular and L.P. memory - Untested
    DDR types very important....get it wrong..you can make a "Hard-Brick" of your device.
    Can you boot into TWRP recovery? Flash Magisk Uninstaller.zip for the version that gave you the problem???
      Yes, TWRP works!
      MMh, I flashed latest uninstaller of Decembre, still stuck. I will flash all uninstallers....let's see...
        Shall I wipe after each flash?
          This launcher was default:
            Gues found it. Recovery shows fingerprint. mine says 20170424. I finally found it here: through 4PDA: https://4pda.ru/forum/index.php?s=&s...ost&p=61476909
            H96pro 2GB / 16GB aml_7.1_s912_q9377-H96Pro_mac-20170424
            Got my box back! Used AML tools to unpack boot.img and flashed through TWRP!!! puuhhhhh....
              But I cant get back MAGISK root ! Android 7.1.1...anyone an idea?
              I forgot which version worked..
                **Updating Magisk on our China Boxes(Uboot/Partition tables??) has had a lot of issues.
                Take a read of this re-post and see if a rooting solution might be recoverable.
                https://forum.freaktab.com/forum/tv-...rom-xda-repost
                • It is better to start fresh with a clean firmware install.
                • Install the newest Magisk
                • Finish install of your favorite apps and settings.
                • Make a TWRP back-up to save on Micro SD card...in case of such emergencies.
                  Thanks for links! I have rooted several boxes and latest version never worked. I tried almost any constellation Manager / Magisk...
                  Important for me is that device passes cts profile.
                  Since I did not want to loose userdata I could not flash amlogic.img but had to extract boot.img from it and flash.
                  Finally got it to work....
                    Last time I tried that...still failed.
                    Make a TWRP back-up while you still can, sometimes a future reboot can suddenly fail..or develop issues.
                      With stable and beta MAGISK I had similar problem - it didn't want to update or just bricked the soft. However since I'm using Canary Debug builds everything is fine (till now ).
                      ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
