### 7 YEAR´S FREAKTAB ALIVE AND KICKING ANNIVERSARY GIVEAWAY ###
Happy Anniversary indeed. Many years ago i got my first Android tablet, and i got invaluable help from here. Since then i learned to fix stuff on my own, but without you giving that initial helping hand, i would most likely have given up. You guys and your users are worth gold. May your deities of choice walk beside you for another seven years - and then some.
I have to say I'm amazed with this web site and the amount of information and help you can find it here. I want to congratulate you guys and I'm glad to have found you my box have just died and I'm trying to restore it. I have not been able to do it yet because of my lack in time and knowledge but I will eventually find a my way.
Wish you all the best and keep doing this excellent work.
My suggestion is for you guys to create a place were we can write things that need to be improved and from there you will have all the feedback you need to do lots of improvements.
Cheers
Guest
There are several really good ROM developers here at Freaktab. I always come here first when looking for info about a particular Android box.
One thing I'd like to see, and participate in, is the development from scratch of a S905X Oreo ROM. Lewy already proved the code is out there to build such a ROM but it takes a lot of work to customize it so everything works well. We should get a bunch of developers together to build the best Oreo ROM and document how it was done so we can do the same for other SOCs as the Oreo source comes available.
There are currently 2958 users online. 0 members and 2958 guests.
