NOUGAT BETA RELEASE FOR UGOOS UT3S
    Android 7.1.2 V 4.0.0b for Ugoos RK3288 Brand devices available now
    IMPORTANT: This BETA release based on Tablet SDK for RK3288 chipset.
    Since it is BETA release, Nougat firmware is available only for manual reflashing (Reflashing Guide), OTA is not available right now.
    In order to make BETA build more friendly, we already add Ugoos Settings and Features.
    Here is a short list:
    1. CIFS & NFS Clients Support, Samba Server
    2. Masked HDMI
    3. Screen Rotation
    4. Root
    5. Hardware Monitor
    6. Wireless Assistant
    7. Gamepad Settings
    8. Debug Settings
    9. User Scripts
    10. USB Mode Settings
    Right now, we are still working on HDMI IN functionality for Ugoos UT3+, firmware for this device will be released later.
    Download Link: Ugoos RK3288 NOUGAT UT3/UT3s/UM3 BETA 4.0.0b
    2. Masked HDMI
    3. Screen Rotation
    4. Root
    5. Hardware Monitor
    7. Gamepad Settings
    8. Debug Settings
    9. User Scripts
    HI ,
    a WONDER is happennig , never thought it will ever come , why now ,
    while my UT3 is bricked really funny for me , hope they release OREO
    like promised for RK3368 , all we can do is sit and wait .
    Hope i can bring my UT3 back to life , that i can test too .
    greetings / gefattern
      HI ,
      You bricked your device using nougat firmware?
        Hi ,
        my UT3 was bricked before , while using it with latest 2.2.0 KK Rom it made a Blackscreen ,
        after un & replug the Power cable it boots up again normal , while later use it crashed and
        since this Point i try to restore it , but always this :
        http://freaktab.com/forum/tv-player-...ed-idb-bricked
        Maybe you know a way to unbrick , MaskRomMode and Loadermode both not work and
        ending up in Errors like : download boot , prepare IDB , download IDB fails , do you know
        how i can bring it back to life , please help , i really dont want to through it away if there is
        any chance to restore , RK3288 has still enough Power .
        Later i upload some more Logs i made .
          Thanks Team Ugoos. Great to see the new firmware.
          Anxious to try it it. Looking forward to the UT3+ version.
            Note Sure as yet
            Flashed OK
            I get the Erasing circle thing on the UT3S
            Now I have a black screen,
            For many minutes, will give it a few more
              Flashed again....nope same deal,
              Used Both dev and batch tool,
              back to ut3s3.1.0(a6) all good
                Confirmed dud. LoL oh well better a non working release then none at all...
                  The UT3S Nougat firmware works great on my HPH RK3288.
                  All Ugoos Settings in right menu.
                  Latest Google Play Store, Total commander file manager, MediaCenter app.
                  Kodi 18 works a breeze, passthrough, auto frame-rate switching.
                  I just need to replace the launcher3 tablet version.
                  Really impressed how smooth it runs.
                  You need to do an EraseFlash then flash the firmware since Nougat uses a different partition layout then Lollipop.
                    Hmm I did erase flash what took you use 2.3?
                    2.39 re loading it now to re try.
                    nope nada ut3 or Rkm no screen formated and also tried mask...
                      I used AndroidDevtool v2.43 bundled with the firmware to flash.
                      Used UT3S v4.0.0b
                        Same Deal here:
                        Erased
                        Flashed
                        Used v2.34
                        I see the erasing A7 Circles few seconds
                        Reboot
                        Black Screen
                          Originally posted by trebor View Post
                          Same Deal here:
                          Erased
                          Flashed
                          Used v2.34
                          Reboot
                          Black Screen
                          Maybe the Nougat firmware only supports certain EMMC or old/new PCB's?
                          Do you have the old big EMMC storage chips or the newer smaller ones, board version?
                          In Firefly Lollipop SDK there was EMMC code changes to support new EMMC, maybe the Ugoos Nougat firmware has some incompatibility or not the same patches since rk3288 tablets might use different EMMC chips?
                          I also flashed my v1.12 Lollipop firmware before I EraseFlashed with the Ugoos Nougat image and flashed the Nougat firmware.
                          I will also try later on older RK3288 devices but they are all bricked and I need to MaskROM flash them first.
                          The Nougat firmware uses a 4.4 kernel instead of 3.10 like in RK3328/RK3229, that is quite a surprise, no wonder I couldn't get my own Nougat booting before, I used a 3.10 kernel.
                          Maybe a typo, you used the v2.43 flashtool not v2.34 and also have the v4.5 drivers installed again, not an older version?
                          Also leave device plugged into the PC for 10 minutes after flashing, don't remove earlier to prevent problems or connect a screen while flashing to see the whole process if not doing it already perhaps.
                            Yes 2.43 flash tool...
                            A6 flashed back in without the need to re erase flash, so maybe something in eMMC type
                            Yes left plugged in, and also tried unplugged from PC soon as flash was verified,
                            Both showed the erasing A7 circle of hope
                            Old version by the looks 2014 PCB date
                            • gefattern
                              gefattern commented
                              Editing a comment
                              I see your Box has the two golden plates in front of Nand too , easy for MaskRomMode
                            Hi.
                            You need use Android tool v 2.43 from archive. In older versions you will get a black screen
