NOUGAT BETA RELEASE FOR UGOOS UT3S
Scooter had used factory tool 1.6 and had a win, for me no such luck.
Using the supplied tool in Archive, Factory Tool 1.6 or Batch Tool 1.8
Tested both upgrade and restore:
All respond the same way
Flashes OK
Get the A7 erasing rings of hope and no more black screen.
Well move along, any more ideas lets know..
Originally posted by Victor View Post
Seems mine UT3 board is the same version. Reflased using RKDev Tool v2.43
my still bricked UT3 PCB is older then yours , my PCB is : PCB / TRN6A V10 2014-8-7 ,
shall try if the new A7Rom works and report the results , hopefully Victor knows a way
to restore .
greetings / gefattern
Originally posted by trebor View PostMaybe the Box is Confused like Me
It is a UT3 and running/was UT3S-userdebug 5.1.1 (may have mentioned A6 Earlier)
Have tried both ut3s / ut3 same result.
Now back 5.1 as previous
we only can hope that they will fix it , fast .
Originally posted by sohot2000 View Postit's work 4 me.
1.LOWFORMAT.
2.ERASEFLASH
3.UPGRADE
4.DONE
my tvbox : Lantic UHD-K2 TV Box with Rockchip RK3288 CPU.
so you pressed "LowerFormat" on Tab1 , change to Tab2 pressed "eraseFlash" ,
and then Upgrade or what ??? you are a happy Guy , does your Wifi & BT work ,
because of different Box , or do you have the same Chips ???
good luck / greetings / gefattern
here are the Logs i made while testing to restore : Logs.zip
hope you or another employee can bring a Solution , if possible
can u upload the first UT3 Rom for my PCB : TRN6A V10 / 2014-8-7 ,
or what about a "uboot.img" file for my Box , will this help ??? , will it
help to flash a "miniLoader ..... Version" to restore , if please upload
the right files for my Box , thanks ,
Hi ,
2.Wifi bt work fine.remote controller not work.
Seems to be a issue with the format of nan on some as works dosent work for others.
but once working very fast clean clear video. Obviously some issue with every firmware but think most will be very pleased with this. Some other devices benifit with it to but be careful as most need a fan or you'll heat up device. Once they find the issue with install maybe update will work for all.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
China way nothing moves fast except money.but not shabby a release on a 4 year old TV box
Hi , u are right , Money rules the World , but we are Human , really dissatisfied me , how shall all the non Devs restore there bricked Boxes with UART or similar if no human support helps . I am not the only on with a bricked Box , look all the 3229/3228 Boxes with Bootloader or IDB problems . We really need a Tutorial for that .
There are currently 1480 users online. 1 members and 1479 guests.
