SCISHION AI ONE Android 8.1 TV Box RK3328 Silver 4/32GB ROM Blue 2/16GB 2.4G WiFi USB3.0 BT4 Voice Control
Originally posted by mo123 View PostDoes this still not work for HDMI passthrough?
1) Check the audio setting in android system settings.
Setting--->Sound--->Audio device--->HDMI Bitstream Selected instead of Default.
2) Kodi 18-Settings--->System settings--->Audio, enable passthrough and DTS-HD capable receiver
Mo, I not sure even YOU could save it.......... Just hope Gearbest does the right thing and give me my $$$ back. It they don't I will be doing a YouTube video, of me pleasuring myself by smashing this box with a hammer........ I can't figure out what to use it for, not good for a Linux server, or even a LibreELEC media player.... Definitely not good for an Android box.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Hello all,
I received a week days ago the new TV Box with Android 8.1 Scishion AI One 4/32GB from CAFAGO and it work fine until yesterday appeared a screen that request me updating the TV box firmware to a new release; I followed the instructions on the screen but, after waiting few hours, it has not restarted and the screen remains black!
I also tried to turn off the power and reset it through the reset button/switch but, without any result; after reset only a black screen appears with the word ANDROID for few seconds and, then, the screen goes again black.
Please can you suggest me a solution?
Thank you.
Thank you.
I connected my box, it said I have the current firmware, no update. Firmware version 2018511.204054Last edited by clarkss12; 29 July 2018, 16:27.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Mine has been sitting in the trash bin for quite awhile. I will take it out and plug it in, to see if there is an update for it. Will let you know how it goes.
Many thanks fo support... Mine is now "dead" I do not even know what version of the firmware had before the update; I did not bother to write the number of the new version.
I hope there is a way to be able to resuscitate without being forced to send it back in China!
Originally posted by colex View PostAfter a month and a half from reporting the update firmware issue for this box, from CAFAGO, I did not receive any solution: repair or refund.
DON'T BUY FROM THIS SITE!
It will mean that I will throw it in garbage and buy another one elsewhere, any suggestion for a new good TV-BOX?
Originally posted by balbes150 View Post
If on the basis of RK3328, I would recommend MVR9. For this model, there are fresh firmware with Android, there is a version of Libreelec, and can be used with a full Linux (as a server or desktop).
Thanks for reply... How I can put the firmware and how I can download it?
This was the answer to your question about the new TV box. View model MVR9. On this forum there is themes Pro new firmware for it, about Libreelec and Linux.
There are currently 1001 users online. 0 members and 1001 guests.
