SCISHION AI ONE Android 8.1 TV Box RK3328 Silver 4/32GB ROM Blue 2/16GB 2.4G WiFi USB3.0 BT4 Voice Control
    As far as I know, this is a closed platform Xiaomi and you will not be able to run anything other than the regular Android.
      Got one of these the other day - was wondering if root/twrp was possible? I've tried using the rockchip factory tool to flash a twrp image that I found here on the forums (http://freaktab.com/forum/tv-player-...ckchip-devices) for rk3328 devices, but after installing the drivers and enabling usb debugging, I can't for the life of me get the rockchip tool - or my laptop for that matter - to even recognise that the device is plugged in.
      Trying to flash the same twrp img using a signed zip (from the same previous post) through the stock recovery - I get an error that system isn't mounted. ADB through the stock recovery also isn't recognised as connected by the laptop, and if I choose to reboot to bootloader, I just get a blank screen and have to power cycle the device.
      Not holding out much hope for this - got it as an impulse buy, it's my first android "set top" box, but after further reading into the different boxes available, it seems like I might have more luck getting what I want with a mibox 3 and the atvxperience rom (https://www.atvxperience.com/), or any other device besides this one, for that matter. There's surprisingly little information out there other than specs and reviews on the AI ONE, and there's not even much of that.
      Thanks in advance for any infos!
      Dave
        Dave
        Yes, you certainly picked the wrong device. Hopefully you can get your $$$$ back from the seller...........
          has any one the stock firmware or the update for this device?
            rk3328_8.1_box_RX4B_RTL8723CS_zhongx_20180822_V13. zip After you put the firmware. Just dont do a system update on your box menu. do a factory reset on your box and then do a system update. I did it like that and updated with no problem. Do it the way I tell you.
            https://mega.nz/#!RBsxUQAI!F5AFKGVE9...Wtv72zs8ws3HDY
            SCISHION AI ONE ANDROID OREO 8.1: ROCKCHIP 3328 2GB RAM + 16GB Firmware
              EDIT, I tried again with Factory tool, but leaving option UPGRADE and not RESTORE, and it worked, thanks so much
              Thanks Antonio, but I had already tried this FW, but it doesn?t work for my box, I have a SCISHION AI ONE 4gb ram 32gb, wifi, Bluetooth, usb 3.0, with the blu led clock
                gday gents
                SCISHION AI ONE ANDROID OREO 8.1: ROCKCHIP 3328 4GB RAM + 32GB Firmware
                1) factory tool v1.6
                2) firmware
                all credits go to our russian comrades on their similar website, kudos to greyz.
                i only recently downloaded files, i have yet to install
                greyz instructions:
                Tv Box memory 4GB RAM + 32GB ROM. Installed FactoryTool from that even. I plugged the cord into the PC.
                Launched the program. I chose the firmware (firmware).
                Toothpick pressed the TV BOX reset until it clicked and held until it inserted the USB cable into the TV BOX in the leftmost socket (not blue).
                The program identified the port. Let go of the toothpick. Clicked start (Run).
                TV BOX was sewn. I pressed the stop. He pulled the cord. Described as I could.
                good luck
                  Originally posted by zeroes_n_ones View Post
                  gday gents
                  https://yadi.sk/d/Tmr7tZ8AFkrKYQ&xid...c8q8TP9kIEOvGA
                  2) firmware
                  https://yadi.sk/d/FlW1v3CxLBhKoQ&xid...4XUaky8MrOR_nA
                  greyz instructions:
                  good luck
                  Thank you so much it worked
                    hi, i solved with this alternative FW, but with NO WIFI: T9_rk3328_d4_IT6334_x88_20180917_r1
                    for my SCISHION AI ONE 4gb ram 32gb, wifi, Bluetooth, usb 3.0
                    thank you at all
                    USEFUL LINKS:
                    link http://www.mediafire.com/file/0v2npl...V%2529.7z/file
                    TOOLS TO DO IT:
                    Factory Tool_v1.63 ? https://goo.gl/kZdkM8
                    Driver Assistant_v4.5 ? https://goo.gl/D4NKrB
                    this is the stock FW https://mega.nz/#!RBsxUQAI!F5AFKGVE9...Wtv72zs8ws3HDY
                    and this works too (V15) https://yadi.sk/d/FlW1v3CxLBhKoQ&xid...4XUaky8MrOR_nA
                      thank you at all
                      USEFUL LINKS:
                      TOOLS TO DO IT:
                      Hello, you know if there are sources of that rom, to try to repair the Wi-Fi theme, thanks.
                        no i'm sorry
                          Could someone solve the WIFI problem? or some alternative rom that works the wifi?
                          thanks
                            Any one knows how to instal twrp and root please
                              SCISHION AI TWO 4gb ram 32gb, wifi, Bluetooth, usb 3.0 , i need twrp for this, anyone please let me know
