I have just received this item:
Here is a pic of the inside:
Some information about stock rom and kernel:
Model number
rk31sdk
Kernel
3.0.36+ hotack@adminroot-X9DRL-3F-iF #45
Build number
rk31sdk-eng 4.2.2 JDQ39 eng.hotack.20130619.161350 test-keys
Vendor software version
RK3188_R-BOX_ANDROID4.2.2-SDK_V1.0.0_130514
Does anyone knows what is the equivalent device discussed in this forum? My biggest problem for now is the 720 resolution (it will be used as a vnc terminal).
Regarding flashing, one has to crack it open to be able to access to the recover button. Would the procedure to flash require a otg cable?
Thanks for your help
