Hello I am new here - so hey everyone!
So we have a H96 Pro Plus android box that for some reason turns the Wi-Fi off all by itself - possessed yikes! I did a firmware update to change to 7.1 nougat and now the wi-fi won't stay connected. I used an ethernet cable to connect to internet for now.
Any help would be appreciated.
First look at the router log..to rule out:
*most common problems: android changes Mac address or two devices with same Mac on network = router sees this as hack attack then drops connection
2: check Mac address of your device : is it 02:00:00?
as this is also a common issue with nougat
3:Install "logcat" app.. to see what android is doing
like this:
Here's how to use logcat:
There are two main ways to do a logcat, within android, and through adb.
Logcat within android can be done one of two ways, through a Logcat app:
Here are two good examples are either: aLogcat or Catlog
I prefer...
router = as in your WiFi hotspot router/device (example: netgear/Linksys/xiaomi/draytek/fritzbox )
It should have a log inside web admin ;
look for : invalid Mac address : dropping connection
Mac address android : settings/device (or tabled or phone) /status
