Mecool KM8 P firmware request
Now i need the newest twrp. Installed the android 6 based twrp, that boots into recovery. But the box isn't compatible with the version from your link.
Getting an error 7 and e1001. Have tried to start the install of the zip with and without system mounted. Just copied the script from a working zip file.Neither helped.
Originally posted by t23 View PostYou have Android 6 running on it now, right? Can you check what ro.product.board says in /system/build.prop ?
Compared the working twrp with the q20x, the kernel is different. Must be a newer kernel used, not compatible with the android 6 box.
Have been able to sign the m8s zip file. Maybe now it's also flashable with standard recovery.
Think it's about the kernel though. The 2GB/16GB just have a newer kernel. Only way to upgrade to 7.1.1 is through ota. Not usb flasing. So that also makes it isn't compatible with any m8s android boxes.
Some info on how to install twrp 3.1.1 on android 6 based mecool km8 p: https://1drv.ms/f/s!ApsAD6QmyMvBhmVgFVFWtIZtFb7yLast edited by mark-1978; 17 June 2018, 10:06.
Originally posted by t23 View PostOh right! I know absolutely nothing about TWRP except how to use it, but now you mention it, i recall it is built against a certain kernel version. Bummer ..
The alfawise h96 pro+ has s912 and t820 cpu/gpu. So the same as the km8 p. There are 2 versions with different memory, just like with the km8 i think.
http://freaktab.com/forum/tv-player-...7-wifi-chipset
wifi probably isn't going to work, since the alfawise has dual wifi. Tried flashing it, it gives a usb initialize error, so not working. Neither is the russian vasly version.
The 1GB/8GB is more compatible with this rom: http://4pda.ru/pages/go/?u=https%3A%...WTJ&e=62234995Last edited by mark-1978; 19 June 2018, 13:21.
Hi,how to install this rom ( http://freaktab.com/forum/tv-player-...oid-7-1/page21 ) Nexus nano to km8 p 1/8Gb? Thank you.
There are currently 1682 users online. 1 members and 1681 guests.
