CX-818 - keeps changing MAC address on ETH
    Guys, I need some help.
    About two months ago I got my CX-818 android box (just google it up and you'll find the specs).
    Anyway, the problem is that the box keeps changing the MAC address on ETH each time I reboot it. With WLAN everything is OK.
    Further to the matter, it simply wan't accept static IP. It just doesn't accept it. I type in the address, netmask, gw, dns1 and dns2. But as soon as I exit menu, it returns to DHCP assigned.
    I tried with the original firmware, latest update and also XTV01 (haven't tried yet with NEOTV but I expect the same).
    Is there any way this can be fixed?
    I need either a fixed MAC address or a static IP in order to do NAT in my router. So ... HELP!
    Tnx and regards to all!
    ok for me .
    CX818 , rom XTV01 ; laucher : apex ; IP of the adslbox : 192.168.1.1
    Wi-Fi: off
    Ethernet: on
    Static IP Setting :
    Use static IP x
    IP address : 192.168.1.125 ( a free IP, not used by other machine )
    gateway : 192.168.1.1 ( IP of the ADSLBOX )
    netmask: 255.255.255.0
    dns1 : 8.8.8.8 ( google dns but you can use an other dns )
    dns2 : 192.168.1.1 ( or other )
    right click on the mouse : android ask to save ; answer ok.
    I test whith
    Quick Boot : ok
    Unplug and replug the power : ok
    Note : the Wi-Fi could not connect when the eth is on.
    Marc
      Originally posted by samarc View Post
      ok for me .
      Wi-Fi: off
      Ethernet: on
      Static IP Setting :
      Use static IP x
      I test whith
      Quick Boot : ok
      Marc
      Tnx for a reply Marc.
      Yap! Everything is the same, with a difference that after the right-click it doesn't ask me anything. It just pops me out and the IP stays DHCP assigned. I will try to flash it once again to see if anything changes. I will also give a shot to NEOTV 1.0.
      On the matter of your NOTE: the same is with mine CX-818 as well. But it doesn't bother me much. I have ETH at my TV, so I do not need WiFi (the signal level is low anyway).
      Regards!
        " I have ETH at my TV " ? You connect directly your CX818 at the TV on the ETH port ? Try whith a routeur or adslbox.
          I didn't express myself well. I have an ETH port on the wall, near the TV. It's a home LAN network connected to a router. Having this, WiFi comes as ... well, excessive.
          Tnx anyway and regards!
            Ok.
            I change my static IP and when I use the right click on a mouse, I have a popup :
            Important
            Whether save Settings ?
            Cancel ok
            I made whith bad parameter and this popup come out.
            When you flash the CX 818 , did you use the restore button?
            A+
            Marc
              Ok.
              Important
              Cancel ok
              Marc
              Regardless left click or right click it just pops me straight out and IP stays DHCP assigned.
              When typing wrong parameters I also get notification, but it's in the bottom of the same window where I'm supposed to type in the parameters. I never get Save settings or any popup whatsoever.
              Marc
              Yap! When flashing I used Restore.
                I suppose that you use the checkbox of the line Use static IP, so I don't know why you don't have the popup.
                Marc
