Hoping someone can help with this. I have a CX-919 and I am trying to change the screen density to a larger size for viewing (from a distance) on a 32inch TV. I am able to successfully do it on 4.1.1 with a density setting of 260. It looks/works great... no issues. I got lucky when I discovered it works at 260 because that is the only size larger than 160 (default) that works.
On 4.2.2 however, I cannot get it to work. The navigation bar disappears and the screen is all twisted up. Sometimes it would display an error about the System UI or crash/reboot. I literally tried every density setting between 161 and 320 and I did not get lucky like I did with 4.1.1.
I have tried it with every ROM on freaktab that is compatible with this unit. You can probably imaging how much time it takes to change the density and reboot that many times.
.gif)
Has anyone else tried to do this or want to do this, or could lead me to do it?
