[ROM] H96 PRO+ SHMOD 7.1.2 (DDR3/DDR4)
    i use the sd card method of flashing and it works fine on my CZ-S32-V2.2
    This is my Custom firmware that i run on my H96 Pro+ CZ-S32-v2.2
    and decided to release it for others to try
    This is what i consider a clean light unbloated and stock firmware and is in essence what i think it should come like from the factory
    (e.g. i didnt slap Shonk all over it)
    The Following Firmware is only for
    H96 Pro+ Firmware CZ-S32-v2.2 (DDR3)
    H96 Pro+ Firmware CZ-S32-v3 (DDR4) (3 reports of the modified bootloader not working on a v3 ddr4 model)
    CZ-S32-v3 (DDR4) (use aml_7.1.2_s912_q9377-H96PROPLUS_mac-20180409_shmod-k4-stockbl)
    it uses the factory bootloader so there's no problems with the ram slight speed bump
    CZ-S32-v2.2 (DDR3) users can also use this ofc if they want
    I may do CZ-S32-v5-v6 in the future
    Complete ChangeLog
    Base Firmware = aml_7.1.2_s912_q9377-S912_mac-20180409.img
    bootloader.partition replaced with a fixed version that powers back up via remote after shutting down with libreelec
    The memory is slightly bumped from 792Mhz to 816Mhz (1632 DDR) feel free to untick flash bootloader if you want to keep the stock bootloader
    logo.PARTITION replaced with Stock H96 Pro+ Boot Logo (was generic S912 Boot Logo)
    Deleted
    /system/app/AppInstaller
    /system/app/Gmail2
    /system/app/Music
    /system/app/OTAUpgrade
    /system/app/PPPoE
    /system/app/SubTitle
    /system/app/VideoPlayer
    /system/app/TestAddon.apk
    /system/priv-app/DLNA
    /system/media/org.xbmc.kodi.zip (kodi addons)
    /system/tts/lang_pico/ German Spanish French Italian TTS removed (only GB and US left)
    /system/preinstall/app-debug.apk
    /system/preinstall/chrome.apk
    /system/preinstall/KDMC17.6.apk
    /system/preinstall/netflix.apk
    /system/preinstall/SystemFota_20160827_CHZHKJ_icon_6.x_singed.apk
    /system/preinstall/TeamViewerQS.apk
    /system/preinstall/TeamViewerQSAddon.apk
    /system/preinstall/twitter.apk
    build.prop edit
    ro.product.model=H96 PRO+ (Set ID back to H96 PRO+ instead of S912)
    ro.product.locale=en-GB (Set Locale to GB instead of CA)
    ro.wifi.channels=13
    #ro.platform.keepbackground.app=com.droidlogic.PPP oE
    #ro.net.pppoe=true
    #ro.platform.has.pppoe=true
    ro.com.android.dateformat=dd-MM-yyyy
    profiler.force_disable_err_rpt=1
    profiler.force_disable_ulog=1
    logcat.live=disable
    Replaced
    /system/etc/hosts (ad blocking hosts file)
    /system/etc/default_wallpaper.png (plain black image so it doesnt mess with the stock launcher now the wallpaper service is working)
    /system/media/bootanimation.zip (Replaced With stock android Boot Animation)
    Added
    /system/preinstall/Launcher3.apk (stock android launcher) uninstall if not needed
    Further Changes Depending on K1 or K4
    /system/app/AmlLauncher_canzone_guodi_7.1.apk (Deleted and replaced with stock AmlLauncher_canzone_7.1.apk K1 or K4)
    /system/preinstall/youtube.apk (Youtube TV 1.3.11 on K1 YouTube TV 2.03.04 on K4)
    aml_7.1.2_s912_q9377-H96PROPLUS_mac-20180409_shmod-k1.img
    AmlLauncher_canzone_7.1.apk (Krypton K1 Mod)
    Netflix Replaced with kodi
    Youtube TV 1.3.11
    aml_7.1.2_s912_q9377-H96PROPLUS_mac-20180409_shmod-k4.img
    AmlLauncher_canzone_7.1.apk (Krypton K4 Mod)
    Youtube TV 2.03.04
    edited stock Launcher with thanks from Krypton
    Feel free to install
    Chrome,Kodi as needed
    there's no point pre installing them as they will be updated anyway
    just install on setup
    Incase Your still confused K1 or K4
    If you want the Stock H96 PRO+ YouTube TV 1.3.11 Get K1
    If you want the Latest YouTube TV 2.03.04 Get K4 (I Run K4 as it supports 4k)
    the id is different for YouTube TV 2.xx.xx
    so the Launcher had to be edited to make it launch from the hard coded Link
    please note i wont be adding anything back in on request
    this firmware is built for myself if you want to make any changes
    feel free to do it yourself
    Files are located in
    H96 Pro+ Firmware CZ-S32-v2.2-v3 SHMOD
    Click image for larger version  Name:	 Views:	3 Size:	130.4 KB ID:	733766Click image for larger version  Name:	 Views:	3 Size:	170.2 KB ID:	733767
    Thank-you.
    For both your generosity and time.
    Will/maybe give it a whirl later.
      Thanks for working on the box, I'll try it out when I get time.
        Thanks for your great work!
        I've tested your new firmware "aml_7.1.2_s912_q9377-H96PROPLUS_mac-20180409_shmod-k4.img" with my H96pro+ 2/16GB and it works very good!
        Especially your modification to "Power ON" with the remote control, if I use Libreelec/Coreelec! That's very great!
        Paul
          possible to change launcher on this rom ? thanks for your work
            I had tried to install into H96 PRO+ 3G/32G, both of K1& K4 cannt installed success all failure on 95~100%
              This is one of the reasons i hardly ever use the usb method
              it can take me 8 goes to get a firmware to write without error
                i tested k4 on my S32-v3 (DDR4) with usb burning tool and my box was bricked , i'm lucky ,i found this video https://www.youtube.com/watch?v=Hgw4S6RgRBE and i'm unbricked ....warning for all
                  Most prob down the the untested bootloader on ddr4
                  use shmod with the stock bootloader
                  aml_7.1.2_s912_q9377-H96PROPLUS_mac-20180409_shmod-k4-stockbl.7z
                    ok i'll test ;-)
                      Me flashing aml_7.1.2_s912_q9377-H96PROPLUS_mac-20180409_shmod-k4-stockbl
                      straight over the top of aml_7.1.2_s912_q9377-H96PROPLUS_mac-20180409_shmod-k4
                      Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
                        i confirm it's worked ,thanks shonk
                          it may well be that you specific h96 pro+ didnt like the ddr4 clock speed bump and some people will be fine
                          or it may be that all ddr4 model's dont like it
                          MY CZ-S32-v2.2 DDR3 is fine with the speed bump
                          thanks for getting back to me btw
                          would be interested to see what results others have with ddr4
                            BTW the easiest way to unbrick is make an sd card image
                            pull the power
                            plug in the sd card
                            hold down the recovery pin
                            plug in power
                            keep holding until it shows upgrading
                            this works from a bricked bootloader
                              you know how i can install live wallpaper ? i's write application not installed
