[ROM] H96 PRO+ SHMOD 7.1.2 (DDR3/DDR4)
Originally posted by ReDaLeRt View PostThis firmware destroyed my box. I had to force it to usb burning method for a couple of times to revive it. DDR4 V3.
even though its posted here multiple times
and there's a folder called "Use only shmod-k4-stockbl on v3 (ddr4 doesnt like the mod bootloader)"
people keep flashing it to v3's
i have renamed the files now to (v2.2 only) on files with the mod bootloader
Originally posted by Shonk View Post
you should read then v3 doent like the ram oc bootloader so you have to flash the stock bootloader version
I recently bought H96 pro+ from Aliexpress, it has 2(16)gb version and hs2734a chipset, while updating the #su I bricked my device, I tried evey possible rom to flash but nothing works, the only rom that flash (aml_7.1_s912_q9377-H96PRO_KDMC_mac-20170811) but it has the wifi drop issue which cant be rectified by deleting the root files as it doesnt have those files, when I contact the seller he provide me another rom (h96pro.H96PRO+_2G(16)_HS2734A_1000M_7.1.2018.04.0 4.12.55), after successful burn through USB burning toll the box didnt respont as it shows the blank screen, I have tried your rom too (h96pro.H96PRO+_2G(16)_HS2734A_1000M_7.1.2018.04.1 0.20.38) on that mega account but it cant get burned stuck at 95%, plz suggest me what to do next will these above roms could flash? plz reply.
I installed stockbootloader version of this ROM few moments ago, as I tried to solve the exact same problem I had on stock ROM version (20180409), but to now avail. My problem is as follows: KODI 18 development builds always crash on startup. The first time I run KODI everything is OK, but after I exit and try to run it again it crashes imidiately (without any error message). This happens only if I try to run KODI by clicking on icon in apps menu. It doesnt matter if I restart, power-off device, the crash always occurs. Interestingly, if I run KODI by going to settings/Apps/KODI/open it works normally. The error occurs only on development builds, 17.6 runs normally from icon in apps menu.
Does anyone face the same issue as I? Any suggestions on how to fix this rather benign but nevertheless anoying issue?
Thank you, Klemen.
Originally posted by Shonk View Postit may well be that you specific h96 pro+ didnt like the ddr4 clock speed bump and some people will be fine
or it may be that all ddr4 model's dont like it
MY CZ-S32-v2.2 DDR3 is fine with the speed bump
I'm trying to load the aml_7.1.2_s912_q9377-H96PROPLUS_mac-20180409_shmod-k4-stockbl (v2.2 + v3).7z firmware, and I get an error zip file is invalid format. Any ideas?
PS I previously bricked my H96 Pro+ as it was not working properly out of the box (I think original firmware was incompatible with DDR4), I managed to unbrick by shorting pins. Now it doesn't connect to the USB burning tool, but rather boots to TWRP, from there I can install an image - I did it with one image but that is still flakey, then I found your image which sounds like what I need, but having trouble installing.
There are currently 3050 users online. 1 members and 3049 guests.
