Edge rk3399 by Khadas for those that like to tinker
Time to try The Edge SOLO:
Edge no Captain no worries mateys
Underside with FPC fitted and working about to Load from SD 3399 version of Armbian desktop version (Debian and Ubuntu)
All Loaded, Flashing Led waiting for logon/Armbian up and running
Testing Ubuntu all good Boot from SD in Captain this time to use ethernet for testing.
More fine work balbes150
Khadas Edge, RK3399Pro Hackable & Expandable SBC
Now Live on Indiegogo
https://www.indiegogo.com/projects/k...pandable-sbc#/Last edited by trebor; 22 November 2018, 01:14.
All good WiFi up and running on the Khadas Edge RK3399
Running Edge Solo, Armbian we can see the WiFi and kicked it up a notch or two.
Some good wifi going on here
Khadas Edge
Arriving soon,
*note: this is a pre-order listing, estimated shipping in march 2019*
Features:
High performance:- Dual-core Cortex-A72 up to 1.8GHz
- Quad-core Cortex-A53 up to 1.5GHz
- ARM Mali-T860MP4 GPU
- 4K VP9 and 4K 10bits H265/H264 video decoders up to 60fps
- 4GB DDR4 & 128GB eMMC.
- 2X2 MIMO 802.11ac Wi-Fi
- 4.x Bluetooth (Basic)
- 5.x Bluetooth (Pro/Max)
- 10/100/1000 Gbit Lan (RTL8211FD, Built-In)
- Dual USB-C ports (3.0 + D.P 1,2, USB P.D)
- Dual USB 2.0 ports, HDMI 2.0a 4K@60Hz with CEC.
- WOL(Wake on Lan)
- RSDB 802.11ac Wi-Fi
- Equipped with 40-pin GPIO header, cooling fan header and a programmable MCU with 16mb of SPI-Flash. Khadas TST (Terry's Smart Tweezers), enter upgrade mode by pressing a button 3 times, works when bootloader is damaged.
- HDMI2.0a and a powerful VPU with 10-bit 4K H.265/H264@60fps playback support.
- Support for dual independent displays over USB-C, HDMI, eDP or MIPI.
- Thin and light with a dimensions of credit card. (VIM Form Factor)
- For stable performance, please use the USB-C 24W Adapter with USB Power Delivery.
- Android
- Ubuntu
- Debian
- LibreELEC
- Dual OS
- Buildroot
- U-Boot
Khadas Website & Documentation.
In the Box:- Edge-V Board
- Wi-Fi Antenna x2
A bit of a look at the Khadas Edge encapsulated in its first Case with Screen, looking good
More can be found how it got this far at Khadas <- Click
There are currently 3089 users online. 0 members and 3089 guests.
