Edge rk3399 by Khadas for those that like to tinker
As Found and for your viewing or using pleasure
Android 9.0 SDK and firmware released for Khadas EDGE (RK3399).
FirmwareAndroid 1
DownloadAndroidSourceCode 2
BuildAndroid 2
Upgrade guidance:The Android Source Code :
SourceKhadas:Last edited by trebor; 28 June 2019, 04:34.
Originally posted by trebor View PostAs Found and for your viewing or using pleasure
FirmwareAndroid 1
BuildAndroid 2
SourceKhadas:
The Khadas Edge V and RockPi4 RK3399's are really changing the landscape of mini pcs.
I don't even want to know how RK3588 released next year will perform and with gaming moving to the cloud, some people might not even need Intel/AMD PC's in a year or 2 anymore to do 90% of their work.
On with the Show...
Next on the Khadas journey is the New Vim EDGE RK3399
Much the same deal as the Vim3 accessories wise to keep keep the theme and cost of casing and bits.
The Only Issue we have is the Edge V 3399 has the Extra USB-C connector under the USB2 port as seen above
Not a problem with a bit of a drill and a file we can make it all fit nicely easy as...we hope
New Case for the the Edge V Rk3399 is the the works.
Ok lets have a look at this build plenty of images about the PCB and how it looks.
Case and PCB etc, Fan still a work in progress
A little Mix and Match with the Colours system here
Bit of a Drill and File
Also Nocked out the Middle Bit on the Base Cover
A windows to the Under side
This will help with the Cooling form my previous experiece with 3399 Chip
Fit the PCB and looking Ok
All Snug and Neat
All together and looking rather SWISH
Update: Kap Case / New VIM1 / 3705 Cooling Fan
Good News Everyone!
Khadas Team will be building a customized Ubuntu LXDE ROM for the Kap Case, that will support the touchscreen and physical buttons. Software performance will be optimised for the RK3399 chip as well.
Early test video of Kap Case booting Ubuntu LXDE Bionic:
If you have an Edge, Captain and TS050 Touchscreen already, you can purchase just the Kap Case for $10 (includes fasteners) to put them all together. If you want to get the full-kit (unassembled), the current promotional price is $250.
> Kap Case at Khadas Shop
Offer ends Monday, the 2nd of December!
Up to 20% off all SBCs (and Toneboards) via this link to Amazon: bit.ly/khadas_store
Khadas
Updated Edge Firmware: Edge_Pie_V191227.7z
Check out the first Post: and as always enjoy:
https://forum.khadas.com/t/edge-andr...m-release/4489
There are currently 4145 users online. 1 members and 4144 guests.
