[ROM] Vorke Z6 / Tanix TX92 TVStock Nexus ROM (Android TV 7.1) adapted to VORKE Z6 PLUS
    I bring a vorke z6 rom (android tv 7.1) adapted to vorke z6 plus all the credict to Guest . I only adapted the rom, so this rom have all the features and bugs the vorke z6 rom android tv
    please visit the link vorke z6 android tv rom to know the features and bug of course and the solves . http://freaktab.com/forum/tv-player-...android-tv-7-1
    install via usb burning tool
    I am not responsible for any brick damage to your box
    http://www.mediafire.com/file/ofzaph...ba+oficial.img
    to solve the HD streaming problem make this configuration
    1 go to configurations playback settings and select on ( level 1)
    2 download vlc player and make this configuration go to vlc configuration- acceleration hardware select disabled-then go to advanced and select audio time stretching.
    Bugs
    sometimes youtube tv locked
    Some solved
    If you have problem with the Bluetooth install a bt fix
    10x much! I will test this. Can you give an example for the HD streaming problems you mention? Maybe I can also help.
      for example, I use a use appflix app and the videos have freezing or a pixel freezing, but is solved with playback settings and select on ( level 1) and vlc configuration "acceleration hardware disable.
        Thanks. What is the difference between this and this one? 7.1.1 versus 7.1.2? http://freaktab.com/forum/tv-player-...7-std-ultimate
          I think this is related to this bug reported on all android devices:
          I also have this with TVHeadend in Kodi and in external players, this seems to be a sw bug with the mediacodec in Android 7. The only solution is to use a player with amcodec support i.e. SPMC 16. Then all streams will play fine without issues if you enable amcodec support. There is an SPMC build that can be used as external media player as it minimizes on video stop. If you want I can post it here also.
            Bugs
            Could you please tell me what exactly have you changed in the ROM to adapt it?
              [QUOTE = barev; n737227]
              ¿Podría decirme qué cambió exactamente en la ROM para adaptarlo? [/ QUOTE]
              El enlace está arriba, comparó el cambio, con respecto a la ROM std ultimate que utilicé y cuando lo usé aplicaciones, la ROM está congelada, esta ROM es en realidad más que std ultimate, es más rápida, estos son los cambios que miro. Intenta si quieres.
              And of course you can post if you want , no problem
