Need help with Educomp Uniclass android Tv box
    I recently purchased an android TV box
    1. COMES PRE-LOADED WITH ANDROID OS version 4.2 OS
    2. PROCESSOR-RK3066 CORTEX-A9 DUAL CORE 1.5GHZ(CON UP TO 1.8GHZ)
    3. INTERNER MEMORY- 2GB R.A.M- 512mb
      https://www.jumia.com.ng/educomp-sma...roduct-details
    I left it powered on while leaving home and came back to meet it no responsive. Every time i reboots it, it powers up but just stays on the splash screen. i have tried to press the reset button and do a hard reset without success.
    Can someone point me to the firmware page and how to reload the firmware ?
    You are joking correct???? Ummm...... here is a review from Feb. 2013 that uses that SoC on an Android box.
    Auf YouTube findest du die angesagtesten Videos und Tracks. Außerdem kannst du eigene Inhalte hochladen und mit Freunden oder gleich der ganzen Welt teilen.
      I just watched the review, it wasnt the same device as mine. Though its the same SoC.
      I really need the firmware to flash this box... i'm already regretting this purchase..
        try :
        disconnect powercord
        hold reset button 10sec...connect power while holding reset..hold for 10 sec release reset
        you should see Androids recovery
        Emty cache then factory reset
        note if you seek a firmware.. you should give more data or pictures from the mobe/motherboard
        like WiFi chip used ? or mobe name and version
        or
        perhaps ask that web store for help
        cheers
