Can you help me identify what this model is and what firmware is correct to upload?
Hi to all is this a Alfawise box? it says S912 it is 2GB Ram 16GB Rom had anyone of you the same box can I upload a custom rom? When I reboot and comes to the hme screen it freezes.You may only view thumbnails in this gallery. This gallery has 5 photos.5 PhotosTags: None
It looks like it but there are some many different versions out there. What you can do is open the box and see what board you have inside. Use a fine flat blade screw driver or a credit card/plastic card to lift up on the top of the box to expose the 4 screws. I would say any of the Alfawise H96pro firmwares should work..
R-Box Pro 3G/16G
SCV7A 7.1.2 / LibreELEC 8.2.4.2
There are currently 2112 users online. 0 members and 2112 guests.
