H96 MAX+ 4/32 or 4/64GB ROM TV Box Android 8
Guest
I was going to try it to, I have 4/32 also, but looks like I won't be..dam to bad it doesn't work on 4/32
Guest
ah, then you didn't use the one posted here by drdino? I am not sure i want to try it, but if it doesn't work you can always revert back to the original firmware
Originally posted by XAVL View Postno bluetooth, an issue with external keyboard recognition (can't move shortcut with long press, can't change langage)
Just got this box, pretty good so far but having no navigation or status bar is pretty annoying so would be good to get Xposed on here so can re-enable these. Also Nova launcher doesn't work fully, sometimes the display will go black for no reason especially in WiFi display when miracasting.
Anyone got a recovery that will work on this SoC? Need Magisk and Xposed to make this box more usable
Any way to flash the new firmware via the box on a SD card or using a linux device?
Sure there must be a TWRP recovery floating around somewhere for this SoC, once we have that we can install Xposed with GravityBox and use the master switch the enable the nav and status bars without apps.
There is an app called 'Status' that brings back the Status bar but doesn't seem to be compatible with Oreo yet.
Right I have got the Status bar back!.. Sort of - downloaded an App called 'Snowball' from https://www.apkmirror.com/apk/squand...-apk-download/
Not quite the full functionality of the native Status bar but at least I can see notifications now! Hopefully will have the proper one back someday soon..
There are currently 3750 users online. 0 members and 3750 guests.
