H96 MAX+ 4/32 or 4/64GB ROM TV Box Android 8
Originally posted by mi.ku View PostHi, thank you very much!
Are these firmwares compatible with my version 4/32GB:
RK3328-H96MAX+_hs2734_8.1.0_20180820.1437.7z
RK3328-H96MAX+_6051_8.1.0_20180822.2103.7z
Anyway thank you a lot for your support.
Originally posted by Gante View PostThen it must go.
Certainly you are doing a mistake in uploading the firmware.
Follow the video step by step.
I have downgraded the firmware successfully. I have tested two versions of the older firmware but without solving my problems..
Based on it I assume that it is hardware problem with my device, that I can?t solve unfortunately..
2 questions:
1. is it possible to backup the FW that is currently installed on the H96 Max + 4/64GB using the android tool or factory tool? I have the July version of the OS currently installed on my box.
2. I see from read through the thread there is a 1437, 2102 and 2210 revision of the FW. Which one should I be upgrading to?
Has anyone ever figured out where these FW's originate from? I mean there has to be some company that is developing fixes for these boxes?
SR
Originally posted by Gante View PostOn the 4/64 it is possible to install firmware for 4/32, there will not be bluetooth that is equally inapplicable.
I think the firmware is the most stable yet:
RK3328_DC_H96_MAX+_SSV6051_RTL8189_8.1.0_20181110. 1616
and box is not so hot!
And what's the difference between these firmwares?
RK3328 DC H96 MAX+ SSV6051 RTL8189 and H96 Max + RK3328
Originally posted by Gante View PostFirmware is usually created or edited by the Chinese retailer itself.
Then they are custom firmware - the users has edited. It's not important at all, it's important how they work!
There are currently 3156 users online. 4 members and 3152 guests.
